Question about Eclipse T180 MP3 Player
My 4gb mp3 froze what do i do
It froze on the rewind button
2 Suggested Answers
  • 742 Answers
SOURCE: my 4gb mp3 froze on me what do i do
Try and clean the button with 91% alcohol, let it dry and try it out.
Posted on Nov 06, 2014
My 4gb mp3 froze on me what do i do
Nov 06, 2014 | Eclipse Mach Speed T180 4 GB Silver Flash...
How do I turn up the volume on my eclipse mp3 180g2
While playing a song, Press the center button once, you will see a little volume speaker at the top, press the fast forward button to turn up, and the rewind to turn down.
Nov 04, 2012 | Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music &...
How to enter USB2.0 MSD MODE ON Ae260 4GB i pod
View model: - Turn on then press and hold the rewind button while plugging to the PC Fuse / E200 : Go to Settings > System Settings > USB Mode & select MSC
For the Clip model Go to Settings > USB mode & select MSC
Jan 06, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa Fuze 4GB froze. It doesn't turn off or
try holding the power slide/ button type thing in the on position until it turns off, then try turning it back on...
Nov 21, 2009 | Audio Players & Recorders
My zen mozaic totally froze, I can't even turn it off. The battery indicator show that it is half charged. I was just trying to rewind a bit, and the whole thing froze. What do I do now?
See if this works. If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Apr 16, 2009 | Creative Labs Zen Touch MP3 Player
Frozen
There is a small pin hole reset button, you will need a small pin to push the button on the inside, hold the button for about 20 seconds.
Dec 29, 2008 | Creative Labs Zen Touch MP3 Player
My 1gb mp3 player has froze mid-rewind
Songs may be fixed-term license or samples. Try resetting player first.
unplug mp3 player from pc
uninstall the Sansa software
reinstall the sansa software
replug the mp3 player
-Tha Mp3 Doctor
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 07, 2008 | SanDisk Sansa e250 MP3 Player
Sreen froze on refreshing data
direct us to the drivers needed to install unit on pc thanks sansa e260
Feb 13, 2008 | SanDisk Sansa e260 MP3 Player
Eclipse T180 MP3 Player Logo
54 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
