Question about Honeywell Programmable Thermostat Heater
Will a rlv450a 7 day programmable thermostat work with a existing electric baseboard with a built in thermostat
  • 1214 Answers
SOURCE: HONEYWELLTL8230A1003 THERMOSTAT, THE SCREEN GOES BLANK THEN ON F
Well, it's an be only one of three things then (in order) -
1) Bad wiring connection, particularly the middle pair of white and black wires connected to the supply wiring, or
2) One of the breakers or fuses has tripped or blown, or
3) Bad thermostat.
If 1 is OK, check 2 (double check if breakers, sometimes they don't look tripped when they are), and lastly, take the stat back and get another one.
The ground is secondary, and it is assumed your living in a house where 14-2, 12-2, or 10-2 with ground was NOT used. If it was, hook up the ground. If not, it's OK. The grounding requirement was added to the NEC after your house or whatever was built. It is not electrically active or needed for this circuit.
Reply back what your findings are. Will be glad to help!
Posted on Feb 03, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
  • 148 Answers
SOURCE: pins on back of thermostat one broke off inside unit weld broke
has it always worked or did you just put it in some require 24 volts to work a wire from the thermostat to furnace c terminal
Posted on May 03, 2009
micromatikal
  • 2777 Answers
SOURCE: I have purschased a HoneyWell
Yes, the wiring should be the same for both thermostats. If you want, you can consult HoneyWell directly to confirm, but I am quite sure this is the case. It wouldn't hurt to confirm with HoneyWell, but you should be safe to proceed, their number is 1-800-328-5111 if you want to check.
Thanks
Tim
Posted on Sep 28, 2010
  • 18 Answers
SOURCE: manual honeywell programmable thermostat
Follow the below link, select thermostat on the upper box, then type CT3600 on the lower box.
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Posted on Oct 09, 2012
I am unable to connect to the Internet even though the email address and password are accurate. This just happened.
Trouble Shooting - - FAQs ' FWD - Honeywell
lyric.honeywell.com/support/troubleshooting/
How do I delete that thermostat from my Lyric app? If you've moved and ... How do I change the email address I use to manage my Lyric? If you already have a ...Missing: programmable ‎accurate
Wi-Fi 7-Day Programmable Thermostat ' Honeywell
yourhome.honeywell.com/.../thermostat/wi-fi-7-day-program...
HoneywellThe Wi-Fi 7-Day Programmable Thermostat is designed for the way you live ...Features such as Smart Response and precision temperature accuracy bring ... your home heating and cooling system, and then remove your existing thermostat. .... Whileconnecting to Wi-Fi, my model RTH6580WF or TH6320WF thermostat is ...
FAQs - Total Connect Comfort
Dec 29, 2015 | Honeywell Programmable Thermostat Heater
I have a few baseboards in the house and two of them controlled by a thermostat just stopped working
I AM ASUMING THESE ARE ELECTRIC BASEBOARD HEATERS, I ADVISE TO CALL A EXPERT BECAUSE YOU ARE DEALING WITH ABOUT 240 VOLTS OF ELECTRICITY, BUT THE PROBLEM MAYBE THE THERMOSAT ITS SELF, CHECK TO SEE IF THIR IS 240 VOLTS AT THE THERMOSTAT, IF NOT MAKE SURE THERE IS 240 AT THE BREAKER, IF THERE IS POWER AT THE BREAKER, THE THERMOSTAT. CHECK AT THE HEATER, ONE LEGG OF THE BREAKER CAN BE BAD, THESE ARE VERY COMMEN PROBLEMS AD OUT OF 200 HEATER PROBLEMS IT IS USALLY ONE OF THESE, PLEASE LEAVE FEED BACK IF THIS HELPS YOU THANKS
Jan 17, 2010 | Fahrenheat Built-In Baseboard Thermostat...
Turned t stat off baseboard is still hot and has been for 2 days
Turn off the power to the baseboard at the breaker box. Remove the cover on the thermostat, check that there is no power going to it, remove the thermostat from the wall and bring it to yor local electrical supply house for a replacement. Most liokely the contacts are welded closed. Make a small diagram of the wiring or take a picture to be able to put the new one on without confusion.
Oct 18, 2009 | Honeywell Programmable Thermostat Heater
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
3) Bad thermostat.
Feb 01, 2009 | Honeywell Programmable Thermostat Heater
Electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Dec 31, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Oct 23, 2008 | Honeywell Electronic Programmable...
7 day thermostat for multiple baseboard heaters
you will hjave to set up a relay box yourself with a transformer to supply 24v to the programmable stat if oyu want to go that way otherwise the only other option is to place the inline water heater timers to turn on and off by time only
May 28, 2008 | Ovens
Installing tandem baseboard heaters
Yes, you should use only one thermostat per power source.
Nov 13, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
53 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
