How do i reset
I cant go to the settings menu to find channels
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 06, 2014
46 inch sanyo led tv won't allow menu to come up on screen.
well I cant be sure because you didn't supply a model number but some models of sanyo's allow one to parental lock the menu bar via password , this prevents kids/others from accessing the settings pages and the channel lock functions , also the key on your remote for menu might have failed as well could be another possibility .
if you have permission of the owner of the set one can preform a master reset if passcode is no longer known , then all your favorites and channels would need to be restored back in
Sep 23, 2015 | Sanyo Televison & Video
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
www.aaatvservice.com
Jan 28, 2012 | RCA Televison & Video
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
Cant get any station other than chanel 3.It wont outo program and says there is no signal but channel 3 comes in.
Its likely the t/v has been programed to work with a cable
box , you can go to menu and settings and try to reset
it , or unplug it for a half hour or more and reset up the t/v
to scan channels.
Sep 02, 2010 | RCA F27665 27" TV
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
How do you get to the set up menu w/out a remote
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
Jan 08, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
Cant get the channel number off the scree
Press the display button on your remote, it should cycle the channel on and off.
Nov 09, 2008 | Proscan 32LA30Q Television
Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Mar 10, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Freeview locked
Phil.. to reset: Info>Menu>Mute>Power Button make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings. if you just want to reset freeview.. 0 0 0 0 then press the colour buttons in sequence.. im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
Jul 14, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
