Question about Dishwashers
<!-- from fixya rte -->I need electrical wiring bosh sps 5432 - Dishwashers
How should I wire a 4 channel amp for alpine sps 600, 609
they are only 4 ohm speakers so just put the front speakers on channels 1&2 or a&b and the rear on 3&4 or c&d since you are using a 4 channel amp thats what they are designed for
Jul 09, 2010 | Alpine SPS-600C Car Component System
Brand new speakers sound blown
it sounds like your problem is bad speakers. I dont think you are under powered. You probley need to take these speaker back if possible. sometimes you will get a faulty speaker, where the wire is glued to cone, the wires are probley not making a good connection. from factory they do screw up. I have had the same problem, it is not noticable by the eye but it does happen. good luck .
Jun 27, 2010 | Alpine SPS-500 Coaxial Car Speaker
I was quoted by lowes that they can order a boshes electric hot wate tank and that it would take 3 40 amp breakers to operate it. are those single pole or double pole and what size wire do you use to wire...
if this is for residential, then you probably don't have the space or amps available in your breaker panel to use one of these. you will need to call an electrician to replace your panel.
a side note... these are VERY expensive to opperate. I wouldn't use an electric tankless unless you have no other choice. Use a tank style electric unit, much much less to opperate
Jun 13, 2010 | Bosch & Tankless LP Hot Water Heater
Installing apline sps- 600c
use only one set of factory wires into the crossover. then from croosover to the alpine woofer and tweeter.
Feb 10, 2010 | Alpine SPS-600C Car Component System
It will run but will not heat up at all. What might be the issue and cost of repair?
with a blind diagnosis, i would say in my experianc ewsith this model, its your heating element
pretty eay reapir
but finding bosh parts is the hard part
call
www.appliancepartspros.com
they do carry bosh parts but you will need the exact model number
heaters usually run around 60-90 dollars
Oct 21, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Im having trouble installing the sps-600c alpine speaker system. i need a wiring diagram or somthing as im un farmiliar with split speakers that dont have a cross over.
Hello lucal_s2000,
Well, actually those 600c's do have a crossover. It's encapsulated in the wiring you got with the components. Your head unit or amp speaker outputs connect directly to the woofers. The inline crossovers have a 12" wire on one end and a 22" wire on the other end. Connect the 22" side to the 2nd set of terminals on the woofers, and the 12" side to your tweeters, keeping all of the positives and negatives straight.
Here's an image of the connections.
5eca958.jpg Hope this helps.
Apr 12, 2009 | Alpine SPS-600C Car Component System
How to un-stack Bosh Washer WFL 2060/Dryer WTL 5410
Did you ever get an answer? I have the same problem...
Mar 21, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosh dishwasher does take electricity
MAKE SURE THE DOOR LATCHING MECHANISM IS OKAY IT HAS A SAFETY POWER SWITCH CONNECTED TO IT
ALSO USE VOLTMETER TO MAKE SURE THE AC SOKET ITS CONNECTED TO IS GETTING POWER
Jan 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
