The fan doesn't blow out air anymore. Can it be fixed
    Problem Solver:
  • 16 Answers
I think it would be cheaper to buy new one the heating element probably went
Posted on Nov 06, 2014
Monitor dishplay good for 5 mim. after that it is a checker board/Gateway
This sounds like it's an overheating issue. Get a can of compressed air and blow out every vent / grill on your machine. If that doesn't fix it, see if it's blowing air out of the exhaust vent. If not, then the fan that cools the graphics card or CPU may have failed or may be failing.
Oct 18, 2012 | Computers & Internet
Where's the fuse for the AC on 98 Olds 88?
So what does the fuse that blows, protect?
You need a wiring diagram & start to test
the components most likely to cause a high
current draw & blown fuse.
Don't keep replacing it.
You know the fan control circuit works, but the
compressor doesn't stay on. Did you monitor
the compressor as the fuse blew?
May have a module for compressor & fan
If so one side failed
The compressor clutch could be bad
May 24, 2012 | 1998 Oldsmobile Eighty Eight
Air Conditioner fan problem. AC fan very noisy and doesn't blow with full power
bushing in motor is probably shot,or some critter put it's nest in there ,either way the motor has to come out.
Jan 11, 2012 | 2003 Chevrolet Malibu
Heater not blowing warm air
the windstar has a problem with heater control doors
Nov 30, 2011 | 2000 Ford Windstar
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
I have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
May 17, 2011 | GE AJCQ06LCB Air Conditioner
NOT BLOWING COLD , DO NOT HAVE THE MANUAL ANYMORE
check wheather the fan is working .check the pre-filter it may be clogged.check the rated amps it drawing if the unit is working .check the blower/blade of the fan motor.
Jun 03, 2009 | Heating & Cooling
Open Questions:
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
