Question about Car Audio & Video
Pyle powered speaker (PPHP123MU) How do you replace the fuse. System completely shut off in middle of use. No power at all. Thanks for any help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Amp or head unit ? Amp power lead fuse should be located in a holder close to the car battery ,the amp itself will have a fuse as well should be near the terminals where the power and speaker leads are located on the unit , head unit will have a fuse on the wiring harness and a fuse from the main power supply fuse panel in the car.
Posted on Nov 30, 2014
Fuse Type ?? Had a Speaker Cord Short out and Took out the Fuse....Can't Read the Little Glass Fuse
I am having the same problem but mine did not come with a fuse and I can't get a hold of Pyle.
Apr 10, 2014 | Pyle PRO PMX602M 6-Channel 600 Watts...
Pyle pcau44 amp
A fuse is blown, check main supply fuse.
Dec 22, 2013 | Pyle Audio Players & Recorders
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
No power when plugged in
If it is new take it back or read the manual. If it is second hand, then you may want to check to see if the internal fuse is intact. These power speaker units usually have an internal fuse to back up the one in the mains connector.
Apr 19, 2013 | Pyle PPHP153MU 15 1000W Powered Speaker...
Pyle 10inch powered subwoofer system installation
i can help but need more info you just puttin in sub & amp or whole system
Mar 06, 2013 | Pyle Car Audio & Video
I need to know how to hook up my pyle pla4278 4 ch 2000watt bridgeable mosfet amplifier
Hi, I assume you are powering regular speakers in the car, right?
The amp needs a power cable from the fuse box or battery.
This cable should be about 6 gage and should have a fuse of about 150 amps.
You will need a ground cable, also 6 gage and connect it tightly to the chassis under the dash.
Disconnect all speaker wires from the head unit, and use a pair of RCA cables to connect the head unit preamp outputs to the amplifier.
Also from the head unit, connect the blue wire to the "turn on" terminal of the amplifier.
Finally, connect your speaker wires to the amplifier.
Your speakers should be rated for at least 500 Watts, or you will blow them with this amp.
Please let me know if you have questions and thanks for using FixYa.
Jan 12, 2011 | Pyle PLA4278 Car Amp
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
1991 Dodge Dynasty 6 cyl.
It could be a fuel-pump ready to die.....or the fuel filter needs replacing.....or could have a vacuum leak. Sounding like that it's starving for gas...it's getting a little...but just enuf to run for a bit. I would start w/ the fuel system. Hope that helps you out for starters.
Dec 30, 2007 | JC Whitney - Pyle High-power Woofers Car...
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
