I am not able to disarm the alarm on my phillips golit. I have used the instructions however it's not working
Help I'm frustrated
chuck943
  • 783 Answers
SOURCE: disarming the alarm
Try this,I think this will work.Unplug the Remote anti-theft module in the right hand kick panel.It will have 2 connectors,one is 22 cavity connector and the other is 26 cavity connector.
Now best I can tell by looking at the Schematics you will have you take the wires from pin 11 PK/LG and pin 22 PK/YE in the 22 pin connector and pin 1 LG in the 26 pin connector and run these to a ground.Then leave the RAP module disconnected. This should keep your electric door locks working and disable the alarm.
Posted on Feb 13, 2009
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
SOURCE: Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Posted on Nov 14, 2009
  • 171 Answers
SOURCE: I have a crime stoppers remote start/alarm when I
You need to hook up the disarm wire also and depend of what car you're working on, it will disarm when you unlock the car.
Posted on Jan 13, 2011
How to ARM and Disarm a self contained ALARM system
An alarm that only sounds for a couple or three minutes, easily defeatable by way of crowbar on plastic? come on.
Nov 30, 2014 | Cars & Trucks
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
I have a 2003 GMC yukon slt xl, i need to disarm the alarm, help!!!
using the key not the remote, lock drivers door from outside, wait 20 seconds and then unlock it, that should disarm the alarm.
Sep 27, 2012 | GMC Yukon Cars & Trucks
How can I disarm the Alarm. I bought my 97 Cabrio used (it didn't come with the remote) The Door locks also don't work. I can't drive it because when I turn the key the alarm goes off and it...
If you don't have the remote then its pretty much useless. I have seen at Pep Boys where they sell replacements for the factory/dealer installed alarms. Or just remove the alarm completely and reconnect everything the way it was.
Without knowing what brand alarm it is a person cannot honestly answer how to disarm it as they all work differently.
If you know a brand and model you may be able to find downloadable instruction on the manufactures web site.
Sep 08, 2011 | 1997 Volkswagen Cabrio
I have a crime stoppers remote start/alarm when I use the unlock button it only unlocks the doors, it does not disarm the alarm. How do I disarm the alarm?
Jan 13, 2011 | 2-Way Remote Starter
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
TDS 3-button keyless remote operating instructions please
RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
Apr 30, 2010 | 1998 Toyota Camry
How do i reset my alarm on a 97 jeep Grand
Here is excerpt from the 1998 Jeep Grand Cherokee Service Manual ... i know you posted under 1997 JGC but this information may be helpful ... by "reset alarm" i believe you meant disarming the alarm?
Arming
Passive arming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned off, and the doors are locked using power lock switch. The power lock switch will not function if the key is in the ignition switch or the headlamps are on with the driver’s door open. The VTSS will not arm if either front door or the liftgate are locked using the key in the lock cylinder.
Active arming of the VTSS occurs when the Remote Keyless Entry (RKE) transmitter is used to lock the vehicle, even if the doors and/or the liftgate are open when the RKE transmitter Lock button is depressed. However, the VTSS arming will not be complete until all the doors and the liftgate are closed.
Following successful passive or active VTSS arming, the VTSS set lamp on the top of the instrument panel will flash rapidly for about 15 seconds after the illuminated entry system times out. This indicates that the VTSS arming is in progress. If the light stays on steadily during the arming, it indicates that the hood switch is closed (the hood is open). The VTSS will still arm if the hood is open, but the engine compartment will not be protected. Once the 15 second arming function is complete, the set lamp will flash at a slower rate to indicate that the VTSS is armed. Disarming Passive disarming of the Vehicle Theft Security Sytem (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter. Once the alarm has been activated (horn sounding, exterior lights flashing, and the the engine no-run feature), either disarming method will also deactivate the alarm. Depressing the Panic button on the RKE transmitter will also disarm the VTSS, but the horm will sound and teh exterior lamps will flash for about three minutes as a part of the Panic feature function. ..." And as an additional note, if you have the courtesy interior lights set at 30 seconds like i do, you have to wait until lights go out (with alarm still sounding) before you can disarm the alarm via passive disarm method... what a pain when you don't have the actual RKE handy... Good Luck!
Feb 14, 2010 | 1997 Jeep Grand Cherokee
Need to disarm the alarm because the remote is not
Jul 20, 2009 | Viper Vehicle Parts & Accessories
Jul 16, 2009 | Vehicle Parts & Accessories
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
