Question about Makita TD090DW 10.8V Compact Li-Ion Cordless Impact Driver Kit
I have a drive bit stuck in the chuck. The last user inserted bit directly in the chuck rather than use a holder, and unfortunately bit has subsequently become stuck. Any suggestions as to how I can remove this, I only have 100mm of the cross head showing, therefore cannot get mole grips on it.
A tough one If can't get hold of it you may be screwed LOL
getting that rammed in the chuck is very hard to get out even if can get a grip unfortunately you can't beat it out you would do more damage And no lubricate is going to help because it was tightened down. Hope someone can help you in this otherwise may have to replace the drill
Posted on Nov 06, 2014
SOURCE: My impact driver doesn't ingage acts like low
Likely to be weak battery due to end of life. Test battery voltage with meter right after charge , then again after use then stop. If voltage changes /drops, battery is worn out. If battery has full charge, check the condition of the battery contacts within the driver. Pull out the battery and look inside. The contacts should look bright and shiney. If dark, may need to replace them, but suspect that the switch is also bad. Good luck.
Posted on Sep 26, 2011
Apr 06, 2015 | Drills
Mar 02, 2014 | Bosch Drills
Oct 16, 2012 | Makita Drills
Jun 27, 2012 | Washing Machines
May 30, 2011 | Dewalt DW056 18 Volt Cordless Impact...
Apr 02, 2010 | Dewalt D25940K Heavy Duty Demolition...
Oct 18, 2009 | kawasaki 19.2v 20 Pc Cordless Drill Set
Jul 12, 2009 | Drills
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Oct 11, 2007 | Dewalt DW056 18 Volt Cordless Impact...
226 people viewed this question
http://www.ereplacementparts.com/makita-... pos 9 remove the parts 9,10,11,12 take pos 17 out setting in a bench-vice with the bit make the anvil hot and try to remove the anvil of the bit.
