Question about Genius Twin Wheel F1 Vibration Feedback F1 Racing Wheel for PS2 & PC
I installed the prifer of Twin Wheel F1 and tried it in 3D driving school and Need for speed Most wanted but i didn't see any vibration action? do i need to send it to the provider?
93 jeep yj 2.5 lift new u joints 31 s drive line vibration is this normal for such a small lift ?
Usually at some point in time
You have to check & correct drive shaft angles,
the best you can, with shims on the rear spring perches
& possibly lower the trans tail housing mount
You have to check the drive shaft for being straight
& MUST have it balanced
What about Shocks?
Did you add ones with the extra travel as the lift?
Did you try different tire pressures?
Have you narrowed down the exact speed & road
conditions it starts to vibrate?
Are the rear wheel bearings on their way out?
How about installing new motor & trans mounts?
Change all diff fluids & go to full-syn
Install or rotate the tires to different spots
Keep notes & make one change at a time
Is the Suspension Bound up any where & not free
to rotate or move since lifted?
Aug 12, 2014 | Cars & Trucks
2006 Toyota Tacoma Prerunner, 2WD, 4.0L V6, 5-speed Automatic has a severe vibration from the speed of 20 mph to 50 mph, then the vibration will slightly deminish.
Is it the engine vibrating or the car? If its the car itself it sounds like u need to have the tires checked & balanced.
Mar 16, 2017 | 2006 Toyota Tacoma PreRunner
Sooo, i have this school laptop. It's a Dell
Remove the hard drive and attach to you computer. Please read the instruction here: http://computer.howstuffworks.com/adding-a-hard-drive.htm
Dec 30, 2012 | Computers & Internet
Need to know what 5 speed transmissions will interchange with a 92 ranger with a 3.0
You didn't mention if it was 2 or 4 wheel drive so I went with a 2 wheel drive. According to hollander the 5 speed transmaaion fits a ranger (2WD) 1991 - 1994 and a Mazda B3000 1994 only. Hope this helps.....
Oct 29, 2012 | 1992 Ford Ranger
Wheel bearing in 2006 solara
Take your tires back off and see if the brake calibers and brake shoes are lined up correctly,maybe the brake calibers are sticking.
Sep 10, 2012 | 2006 Toyota Solara
Vibration when driving '99 Grand Marquis LS
Try a used tire first & then you'll know if wires in radial are broken. Usually causes what you experienced. About $10-$15 for good used
Oct 20, 2017 | Cars & Trucks
Just got tires, alignment, tie rods, cv's. shimmys at 65mph
check the wheel balance, maybe the shop didn't do a good jobor some of the wheel weights fell off.
Mar 29, 2012 | 2002 Cadillac Deville
2005 mercury mariner vibrates a lot when driving up to 20 mph, then it's all smooth. I installed 4 new tires, did front end alignment and rear, did tire rotation and balance, now it is showing ABS
The vibration at low speeds can be due to possible fault in wheel bearings, drive shaft or even with a faulty steering system.You need to hoist up the car and check on all the individual wheels, hubs and also check for the ABS line to the wheel hubs which could have failed or there is a sensor failure on the wheel hub.
Mar 14, 2012 | 2007 Mercury Mariner Premier 4WD
1999 Wrangler - Wobble/Vibration
this problem could be a worn or loose wheel bearing or a worn or broken shock or a worn tie rod inner or outer.
Nov 21, 2011 | 1999 Jeep Wrangler
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Genius Twin Wheel F1 Vibration Feedback F1 Racing Wheel for PS2 & PC Logo
44 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
