Question about Xlerator High Speed Hand Dryer Infrared Senser - Excel Dryer
WHERE DO I FINE THE SPEED SENSER ON 2001 4X4 THAHOE
I HAD ETEST DONE AN IT FAILED SAID I NEED A SPEED SENOR ON IT TOO PASS
How do i reset my pontiac 2002 grand prix in orer to pass emissions?
A new cat what was the original code. Usually you need to drive the car for a while after changing a battery (1/2 hour to an hour) on the road so that the cpu as all the data it needs before going for etest especially the new etest machine. The place that change the cat is it the same place that is doing the emission test?
Aug 12, 2014 | 2000 Pontiac Grand Am GT
I have a 1986 Nissan and while i was driving the speedometer just qui working but my other gauges are working just fine
Many times The crusie control won't work either. the seedometer is triggered by a senser on the output shft of the transmission. You didn't say which car or ruck you have or which engine either so I can't tell where the senser is. The wire can come off the senser can wear out and fail the senser can start leaking and the oil can foul the electrical connection. The speedometer can fail too but it's less likly. If it did it may display the chage in miles without showing the speed.
Dec 02, 2010 | Nissan Hardbody Cars & Trucks
Fit to be tied with etest
I had the same problem, same kind of car, the catyiletic converters were bad. Spendy fix.
Jan 09, 2010 | 2000 Dodge Intrepid
My 1996 Plymouth Breeze failed the CO% and the NOppm tests. What will cause these 2 tets to fail? CO%limit is 0.35 reading was 0.39 NO ppm limit is 467 reading was812 The above readings are for an Emission...
Lots of carbon in the cylinders,EGR valve not working,a dirty or leaking fuel injector,to far advanced timing.
Run 2 cans of fuel injector in 1/2 tank of gas and run it as low as you can before refueling.
I would set the timing back 5 degrees and test again,put it into service mode (check engine light on) if you have to to get timing back to cool combustion for the test.
This should lower the no% and the co% may just pass too.
Do not use premium fuel ( which is just slower burning fuel) when doing etests,or for normal driving if your engine does not require it,
It will cause carbon deposits in the combustion chamber and it will almost always give higher readings when etesting.
Nov 08, 2009 | 1996 Plymouth Breeze
Problem bad hesitation when cold
You should change all 4 O2 sensors, it will run better :)
Also check your compression. Not enough compression on any one cylinder will cause oil blow-by and cause it to fail emissions. Also, the EGR valve can cause the same symptoms.
Sep 13, 2009 | 1997 Chevrolet K1500
1996 jimmy failed an emission test
Did you change the air filter. The fuel filter will have no impact on emmision's but the air filter is a very common problem.If you usually drive it at low rev.'s then before you send it for emmisions test you will need to put it in a low gear and floor it for about a mile the reason is when it is being tested the engine is reved up to around 3500 rpm and any build up of unburned fuel or oil in the exhaust system will put up the emmisions reading.
Aug 19, 2009 | 1996 GMC Jimmy
Won't pass due to emissions
O2 senser usually fail.
anything else fail??? did the inspectionstation tell you what need to be done to pass.??
do you have the print out of the inspection????
any machanic should be able to fix what ever the problem is.
Sep 25, 2008 | 1997 Nissan Sentra
Run hard at 2500 rpm 96 nissan pickup 2.4 5 speed
I had a similar problem mine would hit a rev limiter at 3500 rpms. it would blow black sut out of the tail pipe. Ended up being mass air flow sensor/valorem sensor. almost 500.00 from nissan. fixed it though.
May 31, 2008 | 1996 Nissan Pickup
Xlerator High Speed Hand Dryer Infrared Senser - Excel Dryer Logo
394 people viewed this question
Top Xlerator Home Experts
Donni Steen
Tom Chichester
Are you a Xlerator Home Expert? Answer questions, earn points and help others
