Question about Epson Tm-u220pa Tmu220 Receipt Printer C31c516057 M118a
I have to turn the printer off then on to print the next order any solution?
Seams to take long time sometime to start the print job and sometimes it will be fast but when it doesn't print i can not restart the print job i have to actually turn the printer off and on to print
  • 23 Answers
Many the printers will need more information to perform a printing task. Depending on the task("firmware updates") will provide necessary information to do this. Many times this goes neglected. If you do not get periodic updates for your printer, It is a good idea to browse the manufacturer of the printer. What to do at this point is to print out a self-test page to get current Driver software information. Then go to printer's support website and see if there is an current or "newer" update. Once this is in place it should be tested for it's functionality. If this solves the problem, try this insted of considering the worse. If this does not inspect the operating system of the printer that is sending information to the printer. I have come to understand many drivers for the software that some retailers use usually end up out of business or changed their name. All of these thigs should Always be performed prior to condemning a Hardware issue incorporated in a printer. Hope this helps, Best,Stephen
Posted on Nov 10, 2014
A print job, although cancelled, doesn't leave the printing list.
Please try this approach:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 24, 2012 | Lexmark X1270 All-In-One InkJet Printer
We are using our Konica Minolta Di3510 as our primary printer. It is connected via ethernet. Everything was working fine until we added internet. Now about half the jobs I send to the Di3510 get stuck...
There is too little information to work out your problem here exactly, but I think here is a conflict in your network. I think you have to read the manual of your modem and printer to see for the settings of your network. Is it DHCP? Do you have a fixed IP address for your printer (that is the best thing to do), and is your Gateway address correct with the correct subnetmask. When your printer starts, it 'asks' for a IP address. Your modem 'gives' an address, but it can be a conflict with an other address in the network. If you set a fixed IP address, your printer will always have the same address and can be found... So take the time to look carefully to your modem settings: is DHCP on? Which range will it use? What is the Gataway address, what is your subnet mask? Take also a look at your printer settings: Is DHCP on? Does it have a fixed IP address? And take a look to your printer driver: to what IP address are you printing? Those three things have to match in order to recognize each other.
Sep 06, 2011 | Konica Minolta Di3510 AllInOne Laser...
Has stopped printing has 3 jobs in queue
Hi There
HP often does this. You have to delete or cancel all the jobs in the queue, becausthe first job in the queue failed. Sometimes you gave to tell the computer many to cancel all jobs. Sometimes it is needed to restart your computer before the queue is empty. Only then will you be able to print again
Regards
Andre
Aug 29, 2011 | HP Office Equipment & Supplies
I want to stop the printer from printing a document or a series of pages from a web site. how do I do this?
Go to the Printers (Control Panel) and you can 'Open' printer jobs (right click to find Open). Then select the job and press delete key, or you jan find 'Cancel job' (or similar). Sometimes it can be 1 minutes to wait. Sometimes it will never stop. If you can't stop, you need to restart computer and going to repeat this process again (windows has sometimes big problem with this). If you can't restart windows (sometimes this problem can freeze windows) you can press start button on computer about 6 seconds and it will kill all process and stop computer (only do this if you must).
Aug 27, 2011 | Brother MFC295CNAll-In-One InkJet Printer
When I send a document to print, the document seems to get 'stuck' and won't print. The status bar stays at about 50%. Sometimes it prints, sometimes it won't.
It could be the print spooler of your computer that has gotten disabled somehow. Try to refresh the print spooler on your computer by following the steps in this article in the Lexmark website on How to Restart or Reset the Print Spooler in Windows. Once the spooler has started, make sure there are no print jobs stuck in the print queue before sending out a new print job.
Feb 21, 2011 | Lexmark X4975 Wireless Color Multifunction...
Not printing, green and red lights flashing fast
Maybe you're missing some software your printer needs in order to print. Go to the manufacturer's website and see if there are any software updates for your model.
Sometimes you have to cold reboot the printer. Turn it off and pull the plug for a minute or two. So you get it to wipe out the memory of the print job. While you wait for it, go to the print que on your computer and see how many print jobs are in line? If the pint got "jammed" and you added more jobs to it, there may be more than one in line. With the printer off, go ahead and delete all the print jobs if you can. Once you are up again, try the print job one more time.
Feb 25, 2010 | Samsung ML-2510 Laser Printer
Mechanical error - print cartridge cradle can't move
4 years is quite some time for a printer especially if it is a home printer. Manufactures practically make there printers to **** down. You should be glad it lasted this long. If it carries a memory module then it might of gone out. Printer hold print jobs in there memory so if it gets full, the will stop working.
Mar 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 3940 will only print job in que when computer is restarted?
hi there, you do have a probl;em at your printer, try to test another printer to your unit and if still same problem you have a software problem or else your printer board is mulfuctioning. ty
Dec 24, 2007 | HP DeskJet 3940 InkJet Photo Printer
Print starting over
it sounds like you have a bad main board or a bad carriage motor.
Nov 26, 2007 | OTC TriMatrix OTC560 Printer
Epson Tm-u220pa Tmu220 Receipt Printer C31c516057 M118a Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
