Question about Dryers
I have a Maytag Bravos dryer, Model #MEDB850WR0 that becomes really hot no matter what heat setting is on. I have replaced the thermostat, P/N 8557403(so I would have to assume that the attached inlet
I have a Maytag Bravos dryer, Model #MEDB850WR0 that becomes really hot no matter what heat setting is on. I have replaced the thermostat, P/N 8557403(so I would have to assume that the attached inlet thermistor is good) and checked the exhaust thermistor (the ohms drop as I heat it with a hair dryer). So where do I go from here?
  • Brad Baker
    Brad Baker Nov 08, 2014
    Update to the original post....I checked the inlet thermistor tonight (this is the new one that came with the new high limit thermostat assembly) and it's bad. At 122 deg it's reading 28 ohms when it should be between 17.6 - 18.5.
  • Brad Baker
    So now I have to get in touch with Parts Dr and see what my options are.
  • Dryers Master
  • 9,771 Answers
Have you looked at the vent hose for a lint restriction?
Posted on Nov 06, 2014
Testimonial: "Oh yeah. That was the first thing I checked. I even vent and ran a fish tape from the outside of the house through the metal duct to the laundry room, tied a small towel to the end and pulled it back through to clean out any possible residue. I also checked the blower operation and I have excellent airflow out of the exhaust port."
SOURCE: My dryer won'y blow hot air
Bob, I did not lie, I just checked the heating element orginally with an Olm meter while the element was still installed in the dryer. After more reading on the internet and testing I decide to remove the heating element and noticed it had the short.
Posted on Dec 18, 2007
SOURCE: Maytag dryer model lde612 runs
Hi,Check REPAIR CLINIC.COM.
Posted on Jan 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Posted on Feb 05, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
SOURCE: GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Posted on Mar 23, 2010
Why maytag bravos keeps blowing thermal-fuse
Lots of videos here about that problem.
maytag dryer thermal fuse replacement YouTube
Which thermal fuse. The one on the heater or the one on the lint filter housing? If it was the one on the heater did you replace the thermostat too.
Is the dryer vent blocked, has too many elbows, or too long or otherwise restricted, or is the dryer overloaded.
https://www.youtube.com/results?search_query=maytag+dryer+thermal+fuse+replacement
Sep 08, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Thermal limiter maytag bravos dryer
a thermal limiter is a safety switch designed to keep a dryer from overheating, by either shutting off the heating element or the dryer itself if activated. They don't normally need replacing (unless you know your dryer overheated and activated it). If you have no heat in your dryer, chances are you have a bad heating element--the most common dryer problem
Jan 01, 2013 | GE DSXH47EGWW Electric Dryer
Have a maytag bravos dryer that is less than 1 year old and is running but not drying.
The Maytag Bravos is a good dryer and I am sorry you are experiencing trouble already with it. Since you are not drying, it is probably either the heating element or the thermostat. Both can be checked with a multimeter after disassembly. I would normally look up the parts for you, but I can't do that without the actual model number.
Jun 21, 2011 | Dryers
I have maytag bravos and doesnt blow hot air just cold . i checked went its ok . i think thats heat sensor ? located inside black plastic with one one terminal plog in ? im looking for replacment
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Sep 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryers Logo
99 people viewed this question
Top Dryers Experts
