Question about Bedrug 2000 Nissan Frontier - Crew cab - Truck Bed Liner
Why won't it start ?2000 nissan frontier truck v-6 Engine turns over but won't start. Tried starting(no luck) can hear the fuel pump running with switch on. No apparent fire from plug wires
Was running ok with no problems
    Novelist:
    Scholar:
  • 114 Answers
There are four (4) basic requirements for a gasoline engine to start & run: (1) clean fuel, (2) air, (3) compression, and (4) Spark. Since you say there is no spark, there are several possibilities, the most likely one being a defective ignition coil or a loose or broken wire leading to the primary side of the coil. On newer vehicles (your 2000 Nissan qualifies) you also have an ECU (engine computer) This opens up a whole Pandora's Box of possible things that could be shutting down the ignition system and preventing the truck from starting. If the vehicle has been in a flood and in deep enough water that it entered the cabin area (passenger compartment) then the ECU may have been damaged. Ask around to see if someone has a code reader and can read out whatever ECU codes are set. The results of that may also lead you in a better direction. (Autozone will do this for free if you can get the vehicle to them. They may also be willing to loan this instrument to you - deposit likely required). Sorry I wasn't much help, but engine problems on newer vehicles can be difficult to diagnose.
Posted on Nov 26, 2014
Ok I have a 2000 Nissan frontier 6cyl. I can start it but it will run for a few sec. Then as it's about to shut off its a rough shut down. I replaced the fuel filter. Still the same. I hear the fuel pump...
Have you checked the mass air flow sensor for contamination? Sounds as if the fuel pressure is adequate,but you have another sensor going out, Nissan's air flow sensors out more common problem.
Oct 29, 2014 | 2000 Nissan Frontier
I have a 2000 Nissan Frontier 4x4. One day while driving it just stopped I tried to start it but all it would do is start for a few seconds. And die. I changed fuel filter and started it but would run for...
Could be. Does it sound kind of harsh. Should be a soft whirl sound. Could be the security system. Does the security light stay on? Do you hear the pump running after it starts? You can rent fuel pressure testers from auto parts stores.
Oct 16, 2014 | 2000 Nissan Frontier
My 2000 nissan frontier will try to start but it looks like it is not getting enough gas checked the fuel filter is good
to check the feul pump. have some one in the back and turn the key to the start position and if you hear a buzzing noise the pump work. if you do not hear a buzzing from the gas tank. you need to chech relays
Feb 07, 2013 | 2000 Nissan Frontier
What are the signs and symptoms of a fuel pump needing replaced. Other than the obvious that the car will not start 2000 Nissan frontier V6, 3.3L 4x4 crew cab
You don't hear it running when your turn the key on just before the crank position.
You have replaced the fuel filter and it was pretty much stopped up. (destroyed pump trying to pump through stopped up filter.)
Because it was going bad you couldn't drive fast because it wasn't pumping enough fuel.
Disconnect fuel line and see if fuel comes out when you turn the key on.
Dec 23, 2010 | 2000 Nissan Frontier
Have 2000 frontier tr. auto/v-6 crew cab almost 2 years now i have this issue with staring truck. Most days i stick key in ignition and no problem. some days i have to try 2 to 4 times for engine to run....
Hello. Replace the ignition switch and you may solve your problem. Since it is on again and off again it is difficult to be sure but for the cost....I would replace the switch. J.
Sep 15, 2010 | 2000 Nissan Frontier
My 2000 Nissan Frontier has sputtering problems and the tac goes crazy. changed the fuel pump, sending unit, spark plugs, cap & rotor. what could be wrong?
your tach is run by the engine computer, possible cause. also by the crankshaft position sensor, most likely cause, I would start there. some sensors will run within perimeters and be bad enough to cause a lot of problems
Jun 14, 2010 | 2000 Nissan Frontier
I'm looking for a fuel system diagram for my 1999 Nissan Frontier to check the fuel connections from the tank to the engine 3.3 V-6 I recently replaced the fuel pump,fuel sending unit and fuel filter. Not...
Get a noid light hooked up to the injector (Injectors) This will tell you if the injectors are getting the signal from the computer to let fuel out.
You can have a good fuel pump, and still no fuel if this signal isn't good.
On some vehicles, this signal starts from the distributor. (Module or hall effect)
Nov 24, 2009 | 1999 Nissan Frontier
I fitted new distributor pump to engine nissan frontier 1999 and the engine not running event i started more and more.no fuel at the fuel line which enter to injector.help me
this truck has a common problem with there injector but if u saying there no fuel on line,u gotta check the fuel pump & fuse and relay good luck let me know.
Jun 04, 2009 | 1999 Nissan Frontier
2000 Nissan Frontier Wont start
Hooking up a fuel pressure gauge an seeing if the fuel pump is in fact charging the fuel system . Checking the electrical circuit , fuel pump relay , Instead of guessing as to what the problem is , Test ,Test an test . If you do not know how to do automotive electrical testing there are videos on youtube . Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts When you turn the key on ,not start , the engine computer will energize the fuel pump for a few seconds to prime the system . The fuel pump will not be turned on again if the engine computer does not see a signal from the crankshaft position sensor . Instead of being fixated on the fuel , check for spark . Also find a wiring diagram at http://www.bbbind.com/free_tsb.html Do you know what a wiring diagram is , how to read one ? How to Use Multimeter to Troubleshoot Common Problems
Repairing automobiles the correct way involves years of training , an testing . Fuel Pressure Test
Mar 21, 2017 | 2001 Nissan Frontier Crew Cab
Bedrug 2000 Nissan Frontier - Crew cab - Truck Bed Liner Logo
61 people viewed this question
Top Bedrug Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Bedrug Garden Expert? Answer questions, earn points and help others
