Question about Kenmore Washing Machines
Does Kenmore front load washer model # 402 4903 time for load always depend on the weight of the load? The time it took was always 33 minutes except this morning when I see that the time to completion
Does Kenmore front load washer model # 402 4903 time for load always depend on the weight of the load? The time it took was always 33 minutes except this morning when I see that the time to completion is about 55 minutes. Is there some way I can set the total time?
    Problem Solver:
  • 15 Answers
Make sure the clothes is not overweight, the more clothes above capacity then more time needed to wash, same with the dryer
Posted on Nov 19, 2014
  • Bernard Smith Nov 20, 2014
    I discovered that the problem was caused by the front dial having moved from the setting I had originally set it at. How or why it changed I have no idea but when I reset the dial (no marking on it) I was able to reduce the wash time to 27 minutes.. Go figger!
SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
the dr
  • 447 Answers
SOURCE: GE front loading washer - WBVH6240FWW
Most modern front loading machines have a ESTIMATED time display, this time can change based on the inputs from different sensors and water temperature. So this should be normal.
Posted on Jan 16, 2008
SOURCE: Kenmore Elite HE3 washer
I found when mine doesn't drain there is a sock blocking the drain holes. Open the door and pull out the rubber gasket at the bottoma nd there should be around a half a dozen holes. Good luck!
Posted on Feb 21, 2008
SOURCE: Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Posted on Aug 13, 2008
  • 11 Answers
SOURCE: Kenmore Elite HE3 front loading washer, model
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Posted on Jul 24, 2010
How do you set the time on a log radio
you have to turn it all the way through to the correct time even if it is 23 hours and 55 minutes around. if you go a few minutes too far unplug the clock till time catches up then plug it in again
Oct 16, 2013 | Sony Dual-Alarm AM/FM Clock Radio with...
Setting tochigi tokei co quartz westminister chime
the 2 hour buttons and 2 minute buttons represent a 24 hour clock ie 2:55 is 1452 hours so press first hour button onces the second hour button 4 times then the first minute button 5 times then the second minute button 2 times
Nov 25, 2012 | Seiko Mantel Clock
What's a pacer function?
This pacer function is used to set or regulate the rate of timing. It sounds an electronic tone at the selected rate for maintaining the pace of the activity in beats per minute. You can increase or decrease the rate in increments of 5 beats per minute. For example spinning on a stationary bike at 55 cycles per minute you would set the pacer at 55 beats per minute.
Aug 02, 2012 | Exercise & Fitness
Mitsubishi big screet HDTV after being on for a minute, the scree pops and goes black with some red lines, then the volume turns all the way up by itself.
Do the self check----if set has been unplugged plug it in and turn on for it to fail----when it shuts off ON THE FRONT OF THE SET press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like, 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
What if any error code do you find?
Jun 16, 2012 | Mitsubishi WS-55513 55" Rear Projection...
I have a WS-55313. The screen will go totally blue and a message appears that says- tv will shut off in 2 minutes unless any button is pushed. Pushing any button just makes the message go away. Turning the...
Well not sure what is causing the problem but i think the simple solution is to change your power management settings. I set mine to shut off as well if there is no input signal but the only way it goes to the 2 min. warning is if the cable box is off or its not getting any signal.
Dec 01, 2009 | Mitsubishi WS-55313 55" Rear Projection...
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
Sharp XL-55
I believe you need the remote because I wasn't able to figure it out without it. Hit the clock button, then memory button. The hours should be flashing now. Use fast forward/rewind to change the hours. Hit memory again. Then do the same for minutes. Hit memory one last time and you should be all set.
Sep 10, 2009 | Sharp XL-55 CD Shelf System
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
To turn hours and minutes into decimal
Let's say that the time is in cell C3.
Now in cell D3 type =C3*24
then format cell D3 as Number.
Hope this helps.
Apr 24, 2008 | Excel (SS8SATAS5128400R)
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
