The phone can not start up. Is there a way to start it up again. If put on charge it gets unusual hot.
SOURCE: Phone charges intermittently. Signals charging
* Try to change or check another charger,might some wirings are apparently cut and loses contact.
* as well as changing the battery too, might need a replacement due to a long time use or overused.
* Also check the battery terminal pins if its align,might missing the ground and not triggering the battery interface that's why the power voltage is not supplying accurately.
best regards,
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
SOURCE: I keep getting "charging paused. a battery to hot
You might need a new battery. I have a new phone with my old phone's battery and I'm still having that problem. To get it to charge, I usually take the battery out and put in back in. It usually only charges normally for a few days before happening again though.
SOURCE: samsung galaxy fit mobile not charging even port was changed
maybe charging port was not properly changed, make sure about this and also about charging ic is not water damage.
