Question about Frigidaire ATF6000ES Front Load Washer
WELL I took the back off and I saw the belt off. iI tried to get it back on but I do not know how to loosen the whole thing it s very tight.If I could loosen it I probley could it back on, Any suggestions on how to get loosened up enough to get it back on?
  • 76 Answers
You shouldn't have to loosen it, put the belt on the motor first and half way round the drum pully, turn the pulley slowly holding the belt in place and the belt should go on.
Posted on Nov 18, 2007
How to replace washing machine belt on a Miele Novotronic
I'm sorry but I do not know your particular machine but here are instructions which are suitable for most front loaders.
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK. I have to assume that the back is removable.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
Hope this helps the situation with your Miele.
Good luck,
John C
Feb 12, 2011 | Miele Novotronic W1918A Front Load Washer
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Jan 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I want to know how to change the belt in my ge washing machine . g.e. model # gw983k i seem to ger a burning smell when it starts up with a heavy load.
Remove the front cover of the washer by sliding a screw driver to release the clips.
Loosen the 4 nuts that hold the drive belt motor
Push the motor back to release the drive belt.
Replaced the new drive belt.
Pull motor until drive belt was snug and tighted the 4 bolts.
At the same time, replace the 4 tub dampening straps located at the top of the tub (if too old) so the unit looks like new.
Aug 17, 2009 | Washing Machines
The washer is making loud squealing noises. I took the front panel off to take a close look and notice the motor is able to be moved back and forth. Is this normal? I tried tightening the mounts and it...
Set the drive belt over the drum, loosen the motor slightly, because I think you are cross treading the belt. check the belt before fitting to see if there is any damage to the belt. With your hand put the belt on to the drum, back onto the motor, turn very slowly until the belt finds it's own parallel (the grooves line up), then tighten the motor exactly where it is in place. If there is NO damage to the belt, set the machine onto a fast spin, empty. That should tell you it's a belt problem. But you may have to spend 10 bucks on a new belt. Cheaper than a new machine. Hope all goes go well for you, let me know! Dave
Jul 15, 2009 | Maytag MAT13MN Top Load Washer
HNF7167 Hoover Washing machine no spinning
how do i put the belt on my washing machine
Dec 07, 2008 | Hoover AAA160 Front Load Washer
Putting a belt back on. On a front load Washing Machine
There should be a adjustment to tighten the
belt a bracket similar to bracket to tighten
a belt on a automobile alternator you will
probably need a open end or combination
wrench or you might be able to get it with a
socket wrench
if you can get the belt over one pulley
and over the top of the other pulley and
then turn the pully towards you it may
pop on with the help of a large screwdriver
make sure it unplugged
Nov 11, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
