Question about Brother IntelliFax-2820 Laser Fax
Reciving document in brokwn machine
My fax machine is broken. can you tell me if i will fix the machine i will get still documents which was sent.
  • 159 Answers
On this machine, you will have to be quick. Depending on the machine's internal battery state, you possibly have only an hour at most.
Posted on Dec 24, 2007
Could you please tell me how to use the fax machine to send a fax
You don't give make or model so.....generally; all you do is insert the document to be fax'ed into the feeder on top (normally) dial the number of the other(rxing) fax machine, then press the START button...the pageswill be scanned and sent to the other machine, Petty simple.
Sep 03, 2010 | Office Equipment & Supplies
When I try to fax a document, I keep on receiving error report
It is problem Phone line cable,change it.if you are not fix problem, so you configure your fax machine by Expert technician.
Dec 02, 2009 | Brother IntelliFAX 4100 Laser Fax
Are there error messages on the display or do you want to print something that has been sent? If your fax machine needs toner/drum unit, then that will need to be replaced first. If you are looking for a document that was faxed to someone, you will need to call them and have same document faxed back to you....fax machines have memory for incoming faxes, but not for things that are "sent".
Jul 17, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
The fax will not send and also not receiving.
Not fix but getting someone to look at it.
Nov 18, 2008 | Office Equipment & Supplies
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
29 people viewed this question
James Cagle
James Cagle
Jim Keysor
