An exact make and model number is needed on all dryers, or any appliance for that matter, for an answer.
Every make/model of appliance uses different style parts to hold the door closed. Some are a simple spring clip inside the front panel, while some models can range up to complex electrical-activated locking mechanisms. A make/model will pinpoint your exact defective part.
SOURCE: dryer door will not stay closed tight enough to
Push the pin switch in and see if she will run with the door open. If you put in the metal clips, the usually nylon, receiver part may be bad from forcing it the last few times. These are easily cracked with very little effort, and a somewhat bent prong on the actual door.
