Back to:
Tags:
Copiers
Generic problem for all Copiers
PAPER JAMS
posted by funwio on Nov 11, 2007
There is a constant paper jam in my Xerox work center 610. Every time I try to print or copy a document it stops printing and a message comes up asking me to clear the paper jam. I open and clears it and the problem comes right back the next time.
How do I fix that?
HELP!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 01, 2007
Not Rated (0)
pomtek
Rank:Guru Guru
Rating: 85%, 51 votes
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on PAPER JAMS:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Copiers
SIR, when i am using ADF to photocopy LGL size document...
Ricoh Aficio 1013F Copier
pls help me my Konica 1212 copier is showing F35 and...
Ricoh 6513 Copier
I just got a 6513 copier which I had to dismantle for it...
Konica Minolta DiALTA Di200 Grayscale...
I have a Minolta BizhubDi1610fpI need to know what the...
Toshiba COPIERS - E-STUDIO 650 Copier
My eStudio 650 doesn't print the "even" pages....
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
