Tablets & eReaders Logo
keyona drakeford Posted on Nov 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my tablet without being able to get into it?
I forgot my password for my tablet and I can't get back in it is there a way for me to reset it
Richard Warren
Level 3:
Genius:
  • Master 2,548 Answers
  • Posted on Nov 05, 2014
Richard Warren
Master
Level 3:
Genius:
Answers
2548
Questions
Helped
640153
Points
6606
Perform a factory reset or could be called a firmware reset in your hand book.
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Jan 11, 2013
SOURCE: how do i reset my kurio 7 tablet my daughter forgot the password
factory reset true Recovery mode
vol+/- homebutton last power key
realease home key and - vol when boot
in recovery mode select "FACTORY RESET" enter
"ERASE CACHE" enter
REBOOT DEVICE-
Done
Anonymous
  • 4961 Answers
  • Posted on Aug 19, 2012
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Anonymous
  • Posted on Dec 26, 2011
SOURCE: forgot my password pattern on
Forgot my password pattern how can I reset it back to factory for I will be able to use it
Anonymous
  • 21 Answers
  • Posted on May 28, 2012
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
Anonymous
  • Posted on Jun 16, 2012
SOURCE: Forgot password on a brand new pandigital tablet, how can i reset?
u should really give us something helpful
Granddaughter forgot password how to get back into tablet supersonic android 7" tablet can you help
You can't without doing a factory reset to bypass the forgotten password. Follow the link for the general procedure to reset any Android operating system
How can i get into my tablet? i forgot my password
Google search your tablet make and model and the word reset. This is the only way to get back into the tablet without a password. Caution, you will lose the data on the unit.
1helpful
2answers
Change pin number
hard reset by recovey options
Forgot password for pendo pad
If you can't get in your tablet because you forgot your password, the only way in, is to reset the tablet and setting up the tablet from scratch. You will lose all data, like contact lists, notes, images, and all apps, you did not backup on a computer or in the cloud.
Setting up a password protection on a tablet, was to prevent anyone without password to be able to access your data. Now you forgot the password, you are excluded to the information too.
If there was a general code to unlock every password, that would make the security a farce and worth nothing.
Forgot my password for my sony s tablet
Hello Let me clarify you question. When you say forgot password do you mean that you put a protective password to sign into your tablet and that is the one you forgot? If so there is no way to get back in without it unless you do a factory data reset on your device.. This will erase everything including your personal data unless you have backed it up somewhere and any apps that you have personally placed on the device as well but you can get those back as long as you use the same google account.
Before doing anything if you have a sd card in side you want to take that out or everything that you have on that card will be erased as well.
1.Press and hold the volume up button and then the power button until you see a black screen with blue lettering
2. To get to factory reset use your volume up and down button
3 Use the power button to select it.
4.Then you are going to want to do the same thing again to get to reset tablet
5.Using the volume up or down to get to Reset Tablet and then use the power button to select it.
6.You will be prompted asking you if your sure you want to reset the tablet just click on Erase Everything. Your tablet will begin the resetting process
7. When your tablet comes back up it will be up at the activation screen ie the setup process.
Hope this helps.
Forgot tablet password
I'd suggest clicking on the "forgot password" link usually supplied after the first failed attempt on Android Tablets and follow the instructions. If this fails, do a hardware reset by depressing the small reset button with an open paper clip. While depressing the button restart the tablet. It shouldn't lose any saved files but will reset the OS back to factory defaults and allow you to input a new password.
3helpful
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
