Question about Epson Stylus Pro 7600 InkJet Printer
I'm getting error code 0001000c on my epson 7600 printer. I turn off then on and it prints perfect for about 10 prints then the error code repeats.What needs to be done?
  • 189 Answers
Watch the video at: www.youtube.com/watch?v=nNxMHexgBcg
to see if it answers your question.
Posted on Dec 01, 2014
SOURCE:
SOURCE: Epson Pro 7600 Service required error
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Posted on Nov 21, 2008
dana_eng
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
aicaxz
  • 511 Answers
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
Posted on May 30, 2009
SOURCE: 0001001B error code on Epson 7600 printer
I solved the problem by taking the printer to the local tip, where i had great pleasure in leaving it there.
Posted on Sep 02, 2009
  • 164 Answers
SOURCE: print head clogged
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Testimonial: "thanks v much for the well detailed procedure. If this works it will have saved me a few hundred pounds"
I have a epson 9800 that reads service call error error code 0001000C. I have just done a cleaning , powered up and that is what it reads
If your printer powers up properly and the cartridge carrier moves back & forth than your inkpad needs to be changed. Epson estimates after a certain time of usage that the waste ink gathered in the pads are full. Just goggle for a resetter for your particular print. Its a simple program that overides this restriction set by epson. This is a feature put by all printer manufacturers to prevent the waste ink to to overflow on to the table. you can print now but If you are familiar with tools I suggest you open the top cover and soak up the waste ink with tissue paper (lots).
May 26, 2014 | Epson Office Equipment & Supplies
0001000C error
If your Epson 9880 stylus pro printer displays a 0001000c error code on the control panel screen, then it indicates the PG home position detection error. The printer might display this error and stops printing when it fails to detect the PG home position during the power-on initialization process. This might also occur when the platen gap changing operation is performed after loading the paper.
The main causes of this issue are provided below.
The PG HP Sensor connector might be disconnected from your printer.
The printer would have been disconnected from the Pump Motor connector.
Check if the Pump Motor harness is broken.
See if there is a PG HP Sensor failure.
Otherwise, check if there is a pump motor failure.
Make sure the PG drive gears are not damaged.
The motor driver's fuser on the main board would have been blown.
Follow these steps to resolve the issue.
The Pump Motor connector or the PG HP Sensor connector should be securely reconnected.
Try replacing the PG HP Sensor and the PUMP CAP ASSY. After replacing them, check if the problem is resolved. For Support Call Our Toll-Free 1-866-293-9220
Feb 27, 2014 | Epson 9880 stylus pro Printer
Getting message error 0001000C on Epson Stylus Pro 9800 right after is done printing. The next print after message (after i turn off and on the printer) appears with double image on some areas.
its a carriage home position sensor error u have to clean the sensor and the stip guide which has been attached on carriage... its due to dust on sensor.
Oct 17, 2013 | Epson Stylus Pro 9800 InkJet Printer
0001000C error code on printer start up
This may help:http://files.support.epson.com/pdf/pro76u/pro76uu1.pdf
Dec 10, 2012 | Epson Stylus Pro 7600 InkJet Printer
Error 0001000C print epson 4880
Turn off printer, turn on. If error is still there then reinstall software or call Tech Support
Aug 31, 2011 | Epson Office Equipment & Supplies
Using a Epson 7600. I send the job to the
1. The CR Encoder and the T Fence must be free from dust and dirt or any other
foreign matters.
2. The CR Timing Belt must be free from any defects and the belt must be in
proper tension.
3. The carriage must slide smoothly, free from undue load.
4. Measure the resistance value of the CR Motor. (5.8Ω)
5. Execute encoder checking by “Encoder ” in the selfdiagnostics
menu.
6. All the harness must be connected properly and free from short circuit or
broken wire.
Jan 07, 2010 | Epson Stylus Pro 7600 InkJet Printer
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
1. Turn printer off
Word of warning -
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
533 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
