Question about Video Cameras
Sony camcorder dcr-1p7e
Flashing c:31:22 and arrow pointing up on screen some times it works ok until i rewind the tape
  • ronwashere Nov 11, 2007
    have tried differant tapes even a differn't tape mechonisom but it still flashes as said some times camcorder works ok but most of the time it dos'nt my regards
    will try cleaning then will let u know regards
  • 328 Answers
Here is the only solution:
CODE C:31:22 Symptom/State T reel fault
CODE C:31:22 Symptom/State S reel fault
Correction: Load the tape again, and perform operations from the beginning.
Trying different brands of DV stock does not solve your problem. If this problem continues you could have a tension problem. Replacement of the S & T reel tables will solve your problem.
Posted on Nov 11, 2007
  • Lyle Siemens
    Lyle Siemens Nov 11, 2007
    Also make sure that you remove the tape after every session. Reloading it every time can help get it moving again. Replacing the reel tables have to be done by a professional unless you are determined and an electronic savvy. A reputable place will find one for you. This happens to worn out reels. It is possible that there is grease in the wrong place, preventing the proper turning of the reel.
  • Lyle Siemens
    Sony had a habit of putting too much grease in the gears and sometimes it spread into the tape compartment. Careful cleaning may help.
When turning on to vcr or camera, camera beeps repeatly
Sounds like the camera ATE THE TAPE will not eject,fastforward, or rewind.. This will need to be repaired , worse case a belt slipped or something got misalligned inside, I would recommend a camera shop so you can save the tape otherwise digging into this yourself could stirr up more issues in the long run. Please do be considerate of facts here that we cannot see your unit and this error is because the tape got ATE or something got jammed.
Thanks please do leave some feedback and ratings for your free answer today.
May 29, 2010 | Sony Handycam DCR-HC14E Mini DV Digital...
Cannot playback tape on Sony DCR HC36
Have you try cleaning tape? Sometimes, it is just a dirty head. Try to clean it, see if it helps.
Jan 06, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Blinking arrow and numbers, won't eject, play, rewind, fastforward
your camcorder must be broken. a specialist should work on that. go to your nearest technician to help you with. they have a tools for that. hope that helps!
Aug 08, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Touch Screen on Sony DCR-HC32 Camcorder Does Not Work
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Mar 17, 2008 | Sony DCR-HC32E DV Digital Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Video Cameras Logo
468 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
