Question about Protron PDV-288 7" LCD Portable DVD Player
How do you invert the pic to install dvd player in vehicle
I would like to install the dvd player in my vehicle yet i do not know how to invert the picture due to not havin the remaote any longer
  • 979 Answers
You'll need to at the very least borrow a remote..accordianman
Posted on Feb 19, 2008
DVD player gives me the sound but the screen is dark
There is a inverter next to the screen under the plastics either below the screen or next to it. This sounds like a bad transformer witch is located on the inverter board. They can be ordered on line or through most laptop stores. They are not hard to change but a common problem. make sure you know what you are doing before you attemp this. Thanks
Oct 05, 2010 | Coby TF-DVD7333 Portable DVD Player
I turned on the dvd player and them the screen came on and then immediately the screen went black and I cannot get the dvd player back. It is fully charges and I also tried to play using the dvd player...
This can be a faulty backlight bulb in the screen but more likely the screen inverter has developed a fault, replacing the inverter would probaly cure it or check the connections to the inverter for a dry joint and possibly reflowing the solder may also do it.
If your not sure what the inverter is then I would throw the player away and get a new one.
Nov 23, 2009 | Initial IDM-9520 Portable DVD Player
Sony LCD TV has Dark Picture
the problem is not the lamp.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
May 30, 2009 | Audiovox D1210 Portable DVD Player with...
Installation question
You don't need a dash kit as the vehicle has a DIN opening already. You will need a wire harness for the vehicle, Metra 70-5511 and a 12 ft. A/V RCA cable to go from head unit to the monmitor, and some patience :-)
Here is a pic of the harness http://www.newegg.com/Product/Product.aspx?Item=N82E16882309120
Take care,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 24, 2009 | Legacy LMR1344 Car Monitor
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
How to connect up my tv with a vcr and a dvd player
WELL DEPENDING ON WHAT KIND OF TV U HAVE,,THAT SAYS WHAT CONNECTIONS TO USE FOR BEST PIC. LIKE THE DVD PLAYER YOU WOULD, NEED A SET OF RCA JACKS,, THERE YELLOW,RED AND WHITE,,YELLOW IS VIDEO,,, KNOW IF ITS GOT ON BACK OF TV AND DVD PLAYER ,,COMPONENT JACKS ,, WHICH WILL GREEN ,BLUE,,RED,, . YOU WANT TO USE THOSE,, THAT WOULD BE YOUR BEST PICTURE. THE VCR,, ,, I KNOW MOST PEOPLE USE THAT CABLE TYPE WIRE,, WHICH WILL WORK JUST FINE . BUT AGAIN FOR BEST PIC,, USE RCA JACKS,,HOOK UP SAME AS DVD PLAYER. THANKS AND GOOD LUCK.
Oct 05, 2008 | Televison & Video
None of my DVD players will show photos from CD-R photopro (maxell)
What type of pic file are you burning to the CD? What format are you using as a burn profile? Without knowing this, my only guess is your DVD player can't show the pics in the format used, so you need to work around that problem. Shouldn't be too hard, reply back with more info...
Feb 17, 2008 | Emerson EWD2203 DVD Player/VCR
Insignia vehicle installed dvd player problem
You have a damaged LCD inverter board. The unit can now be used as a player only and you'll need to connect it to the A/V outs to see video clearly and without the lines.
Dec 23, 2007 | Insignia IS-PDVD10 Portable DVD Player
How do i invert the picture?
Don't believe this player supports this function..accordianman
Nov 11, 2007 | Protron PDV-288 7" LCD Portable DVD Player
LG 77m monitor
Is the problem on all signal to display? If any signal is dark, the inverter is going bad.
Mar 28, 2007 | LG Studioworks 77M Monitor
Protron PDV-288 7" LCD Portable DVD Player Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
