I get an error message "ordinal 231 not found in dynamic link library ietutil.dll" when i boot my laptop and i think the problem is making my laptop performance very poor.
Hope the instructions in this post may help. It lists several common methods to deal with the required dll not found error.
Several Tips to Fix Required DLL Was Not Found Error Fix EXE DLL Errors
SOURCE: Won't boot/reboot after turning off yesterday
1. boot from a Windows CD and go for the repair option.
2.
Copy usp10.dll from c:\windows\servicepackfiles\i386\gdi32.dll to
c:\windows\system32\usp10.dll. (Do keep a backup copy of the old usp10.dll in c:\windows\system32 directory )
3. Reboot normally
http://www.aa1consulting.com
SOURCE: Hi,
repair. I could give you the disk if you havent got it. press "R" on setup screen (not in Windows)
SOURCE: the ordinal 685 could not located in the dynamic
the ordinal 685 could not located in the dynamic link library iertutil.dll.
SOURCE: Error message: procedure entry point PowerReadACValue could not
tvagente.exe
is used to use computer as a TV. If you do not use it, you may want
disable it. It uses excessive system and memory resources If you are
not using the TV application, you should remove it to improve your
overall system's performance. anyway try in run-msconfig-startup the entry for tvagent.exe and disable
SOURCE: Acer Aspire One error when trying to connect to
1. Install another browser: For e.g. FLOCK
2. Are you able to browse?
If so then we have isolated the problem to Internet Explorer:
1. Which version of IE are you using?
Either way:
1. uninstall it completely
2. Download and reinstall the latest version of IE
And just in case please do a VIRUS SCAN:
1. DiskClean up of C drive (always do this before a virus scan)
2. Total Virus Scan of Hard Disk (make sure Virus application is updated first)
About System Restore:
Windows does not allow you do to a restore from before it happened because it did not save any restore date from prior to (perhaps system restore is not enabled so be sure to double check this); therefore:
1. You're going to have to try to fix this isolated problem manually
OR
2. RESTORE to factory settings: take all ur data off and restore to factory settings and then put ur data back thereafter.
CAH
CAH
