Pinnacle Studio 16 Ultimate Logo
S
Sibongiseni Posted on Nov 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pinacle Studio 16 is not running smooth if I edit AVCHD 1080. my computer is running windows 7 64 bit and Ram is 4 processor is core i5
Steven R
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 100 Answers
  • Posted on Nov 05, 2014
Steven R
Expert
Level 2:
Filmmaker:
Answers
100
Questions
Helped
93832
Points
373
Although your systems appears to meet or exceed the minimum system requirements for Pinnacle Studio, in HD 1080 mode, the system can easily be overwhelmed.
In HD mode the demands on the video card increase geometrically.
You don't mention what video card you are using or the amount of dedicated memory that it has. If you are running off a system that uses the main RAM for the monitor's video or an underpowered video card then the system may not run smoothly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
What ram spec for h67h2 ad d2
DDR3 at 1333mhz. It will take 32Gb, but it will only use that if you have a 64 bit operating system.
6answers
I have bought a cannon XH-A1 HDV camera but find i cannot capture scenes using Pinnacle Studio plus v9 could you please advise me on what is required, may be studio 11 plus for windows XP will solve this?
Hi there
Pinnacle Studio Plus V.9 can only be used for editing DV and not HDV however Pinnacle Studio Plus V.11 can be used to edit both DV and HDV.
Please remember to put a good rating on this post.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Step 2. Choose Apple ProRes for Final Cut Pro.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
1helpful
Dell Studio 15 runs slow... My Dell studio 1558 takes long time to boot & processing is also slow,i have tried disk cleanup and defragment hard disk but nothing worked,it has the following...
sound like your core is geting hot is your fan working is so try cleaning it with small birst of air plus check your bios settings..if not overheating try factory settings...
Is it possible to work in Pinaccle Studio 9.4 in a I 3 or I 5 processor or windows 7 ?
if u want to use pinacle or any editing software the best option is still windows xp but if u do not have windows xp pinacle 9.4 should work with windows 7 u may have to change the compatible os option but let me tell u the rendering part in pinacle and windows 7 they do not match in regards to the speed to u may land up spending more time waiting for the render part
Which laptop for 3d animation .use softwares maya,max ,video editing dell's config: Intel® Core™ i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA®...
dell\'s config: Intel® Core? i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA® GeForce® GT 420M graphics with Bluetooth (with WIDI) 4GB 1333MHz DDR3 SDRAM (1 x 4G) (operates at 1066MHZ for Core i5 processors) with increased RAM will work fine
1helpful
3answers
I want to install win7premium32-bit to my pc
It requires at least 2 gb ram and c2 duo or higher. Be sure you have that min with your pc. next you need windows cd. insert it int drive and press F3 or any key to boot with cd. It's then very simple just do as pc says. In format using type choose NTFS next just proceed as directed and you are done.
Asus notebook windows 7 totally frozen..."not responding" Can't even exit without holding power off.
This is due to the fact that your ASUS Eee PC 701 PC does not offer minimum System requirements to run windows 7
Microsoft has published their minimum specifications for a system running Windows 7
as
  • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 GB RAM (32-bit) / 2 GB RAM (64-bit)
  • 16 GB available disk space (32-bit) / 20 GB (64-bit)
  • DirectX 9 graphics processor with WDDM 1.0 or higher driver
But I suggest following as min to run smoothly
  • A Dual Processor (AMD or Intel) – you can use a lower Celeron or Pentium Processor, but you will regret it
  • 2 GB RAM (operating memory) – you can use less, but you will regret it
  • 16 GB available disk space and another 20 to 30 GB if you plan on running applications
  • A Vista compatible graphics card (DirectX 9 graphics process with WDDM 1.0 or higher)
  • A Vista compatible sound card
  • Vista drivers for any other unique hardware you have on or connected to your computer
If this helps please do leave a vote and rate for the solution.
AVCHD Editing
AVCHD Converter for Mac is the best software for Mac users to convert AVCHD files from popular camcorders, including Sony AVCHD, Canon AVCHD, Panasonic AVCHD, and JVC AVCHD, etc.
Upgrading to Windows XPx64
The answer is no because your motherboard still only supports 32 bit drivers. Read On.
Here's what you need to use Windows XP Professional x64 Edition
Important: Windows XP Professional x64 Edition cannot be successfully installed on x86 (32-bit) systems or 64-bit Intel Itanium–based systems. 32-bit device drivers are not supported on Windows XP Professional x64 Edition.
• Computer with a supported processor: AMD Athlon 64, AMD Opteron, Intel Xeon with Intel EM64T support, Intel Pentium 4 with Intel EM64T support
• 256 megabytes (MB) of RAM or higher recommended
• 1.5 gigabytes (GB) of available hard-disk space (additional space may be required if installing over a network)
• CD-ROM or DVD drive
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• Keyboard, Microsoft Mouse, Microsoft IntelliMouse, or compatible pointing device
arrow_px_up.gifTop of page Additional items or services required to use certain Windows XP features • 28.8-Kbps modem or fax modem and service provider required for Internet access (service provider may charge a fee)
• Sound requires a sound card and speakers (USB speakers require a computer with USB support) or headphones
• Remote Assistance requires that both parties be running Windows XP and be connected over a network
• Remote Desktop requires a computer running Windows 95 or later and the two computers must be connected over a network
• DVD video playback requires a DVD drive and DVD decoder card or DVD decoder software and 8 MB of video RAM
• Windows Movie Maker video capture feature requires an appropriate digital or analog video capture device and 400-MHz or faster processor for digital video camera capture
Top Pinnacle Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Pinnacle Home Expert? Answer questions, earn points and help others
