Question about Umax Astra 3400 Flatbed Scanner
Light stuck the cariiege is not moving
    Sergeant:
    Champion:
  • 306 Answers
Unistall software, unplug scanner, restart pc, load software and connect scanner, if problem still exsist it the scanner and needs to be replaced.
Posted on Nov 11, 2007
2008 dodge avenger stuck in park but cluster reads neutral
First thing to do is check and see if the brake lights work, the brake lights power the release solenoid so you can move the gear selector from part to the desired gear.
Jul 15, 2016 | 2008 Dodge Avenger
My crysler 300 - C is stuck in park and wont let shifter move i move the pink pin under shifter plate left and right and still wont shift
This car uses a park lock system, it is operated by the brake light circuit, so is if the brake lights are not on when the pedal is pushed the park lock will not released. if the brake lights do work you have other more serious issues **** as a defective lock solenoid. The owners manual gives the bypass procedure around this problem, check the index.
Sep 27, 2012 | Cars & Trucks
Driver seat is stuck all the way back.
Sounds like you have something stuck in the seat track look under the seat with a flash light to see if any thing binding the seat from moveing or if something looks broken and is stuck in the track spray with WD40 that will also help then work it back and forth until it starts moveing freely
Dec 04, 2010 | 2004 GMC Envoy
Battery drain overnight
Can be a relay stuck. Make sure all the P/W will go up and down as they should. A relay can be stuck in the up position. The window switch can also be stuck. Check the Power Seat to see if a relay is stuck or the switch is defective. Move the seat back and forth, up and down, and recline. If a relay is stuck it will move on it's own. Are you sure the radio is not on all the time? Have you checked all the lights? Under hood, trunk, glove box, courtesy, etc?
Jul 16, 2010 | 2002 Chevrolet Malibu
An automatic 2002 Mazda Millenia V6 2.5L is stuck in park
When you experience this problem, check to see if your brake lights are coming on. It could be as simple as a brake light switch malfunction. If the brake lights are functioning as the problem is occurring then you could for example have a problem with the shift interlock solenoid.
Jul 28, 2009 | Mazda Millenia Cars & Trucks
Whirlpool mo 110753790 It gets stuck in the wash cycle & will not move unless you move the dial. This happens while the heat light is on & light will not go off which causes the dial to be stuck....
Timer behind dial is defective if it will not advance on it's own. Either continue to advance past the defective section of replace it.
Jul 06, 2009 | Dishwashers
My gear shift is stuck and will not move from park to reverse. I had backed out the car and turned it off. when I went to move the car, my gear shift will not move out of the park position.
do the brake lights work? the system has a lock out that keeps you from moving out of park unless the brake circuit is activated, hence no brake lights no park lock out release, if the brk lights do work u most have a stuck or defective park lock out solenoid.
Jun 22, 2009 | 2005 Chrysler 300
K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Apr 14, 2009 | Kenmore Dishwashers
Umax Astra 3400 Flatbed Scanner Logo
61 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
