2006 Nissan Altima Logo
J
Jamey Nunez Posted on Nov 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car will not start and when key is on making a humming noise. what is that?
Don Cahala
Level 2:
Novelist:
  • Expert 239 Answers
  • Posted on Nov 05, 2014
Don Cahala
Expert
Level 2:
Novelist:
Answers
239
Questions
0
Helped
63030
Points
469
Could be the fuel pump. Any fuel leaks? If so, stop and see a qualified mechanic.
Is the sound coming from the rear of the car? Open the gas cap and listen at the fuel intake. Is the sound louder? If so, the fuel pump may have a rotted line attached to the fuel pump in the tank.
If he sound is coming from the dash or under the hood it could be a number of other issues.
1helpful
Should motor make humming noise - instead of making no noise - if starter Capacitor is the only thing faulty ?
Not always, just replace the cap to start with. Sometimes they howl an other bearing make a noise.
Car makes a humming electrical noise under hood,when I try to start it just clicks
The humming noise might be your cooling fan(s) coming on with the key in the "on" position. Check your battery connections for corrosion. Have someone jump the battery to see if the additional amps will turn the starter. Sounds like a bad starter though. I would need to know the year, make, model to be more helpful.
My 2001 chevy malibu had been working fine up until this afternoon it turns but wont start,itmakes ahumming noise even when i turnoff key.
That humming noise may be your fuel pump burning out. Try turning the key to the on position while someone else listens near the gas tank. The humming should only hum for a few seconds so you won't have time to listen yourself unless you can hear it from inside. If the hum continues and doesnt shut off, it is likely a bad fuel pump. It is normal to hear a small hum for a couple of seconds , but when it starts getting weak, it will hum louder, longer, or not at all
Car wont start made a clicking noise first time, now no noise just a short humming sound. 95 Grand Marquis V8
check your battery terminal wire connector make sure they are secure and clean of any corrosion . and as for the humming sound I believe that is your fuel pump running when you turn your key to the on position
HUMMING SOUND
post a photo with finger pointing to object humming.
we can not ever guess this.
there are 3000 parts on the car, and ive seen like near each make noise moving fast, 1 time the other.
1: check all fuses
2: makes sure battery voltage is at 12.6vdc rested, key on still close to 12.6vdc , still makes hum.?
my guess is the battery is drained but no proof, im not there use my voltmeter.
1helpful
2003 dodge caravan will not start. Makes a clicking noise, and dash shuts off, then makes a humming sound.
im going to say an almost dead battery .the hum you hear might be the fuel pump.you never heard it before because the van normaly starts .so boost your van if it starts you may have to replace the altenator the guages, no worries many cars do that .thats a code needing erased and if you disconnect the battery that may go away.
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
2008 dodge ram had transponder key made and now truck wont start battery is good only makes hum noise when key is in on position
When the start for 2-3 seconds and die it's mean just one thing usully , you need to check if the security light blinking and if it doe's you need to call the locksmith to program the transponder key. Locksmith East Aurora Ny 24 Hour Locksmith 716 249 2944 in East Aurora Ny
3answers
I have a '96 cavalier that makes a humming noise in the gas tank within 5 seconds of starting. I have tried two fuel pumps but the noise is still there!!!
Your fuel pump is supposed to hum, when you turn the key it primes the system and it will hum. When the car is running the fuel pump is running and it will hum. If the noise is excessive then try a higher quality fuel pump, it may be less noisy. You will hear the fuel pump on a lot of vehicles tho when you are sitting at a stop light with your radio off and everything quiet in the car.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
