If you want to make your Nokia E63 work with all GSM SIM card, you need to unlock the network restriction from it. You can unlock a Nokia E63 safer and easier using unlock code. You can get the accurate unlock code for a Nokia E63 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia E63 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E63.
3 - Compose #pw+CODE+1#.
4 - The Nokia E63 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E63 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E63
SOURCE: MobileUnlockGuide.com
When you have a sim in the phone, it could inserted the wrong way around, be defect, or could have dirty or oxidised contacts.
Try to eliminate all causes, and if you are sure the sim is defect just goto your provider with the phone and let them insert a new sim and put your number on that side.
SOURCE: contact service provider
U have to unlock u'r phone, it is locked to a different carrier then the one U are using
hi I was installing a new skin for my motorola razr v3, then the screen just froze now im trying to turn it on but it won't work
SOURCE: emergency calls only and not showing service provider
sounds like either your sim card isnt inserted correctly, or the slots arent turned on. sim card slot 2 is the slot closest to the phone, gold chip faces up, sim card slot one is slightly elevetaed off the phone, gold chip faces down. make sure it is inserted all the way down. perss fimly. then go to SETTINGS>DUAL SIM SETTINGS>DUAL SIM OPEN>CLICK OK. This opens up both sim card slots. after you find out which slot you are going to use, you can repeat these steps and only have opened the one you are using.
SOURCE: y blackberry keeps saying insert sim card when its
check that the sim card is clean and not damage din anyway. Also check the connections on the blackberry where the SIM goes.
If the problem persists then go back to your network provider and see what they suggest. If they cant help maybe contact blackberry.
SOURCE: WHY DOES MY PHONE SAYS INSERT SIM
try taking SIM and battery out placing it back in an powering on.
If you try this and it still does not work you may need a new SIM card.
Take it to a local dealer they should have a new SIM they will put your
number on it and you will be back in business.
If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
good luck
