Question about Zenith XBV443 DVD Player/VCR
Shows "reading" but will not change to anything else
Wondering if you can help with the above mode. When DVD inserted, screen indicates "reading" but never changes. Would cleaning help or is it possible that the unit was zapped in a power outage. We have had some here in Myrtle Beach due to construction.
  • 2 more comments
  • j2569 Apr 05, 2008
    same thing
  • edupes May 04, 2008
  • Anonymous May 12, 2008
    I am having the same problem dvd never reads and makes noices
  • Anonymous May 22, 2008
    reads disc for a moment then machine freezes
I am having the same issue and was wondering if anyone had any suggestion. I hate to replace this unit as I had never had any problems prior to this one.
Posted on Mar 04, 2008
My Samsung laptop model no. is R418. When I insert any disk in the DVD drive, and double click on it it shows a blank screen without any files. It is recognising the cds and also running the auto play but...
You typically get a read error from the operation system if there is a problem reading the disk, so it is likely that the DVD really is blank. Try gently washing and drying (with soft tissue not heat) the DVD. Then try another computer. If it reads the data, the burn a new DVD.
Mar 13, 2011 | Samsung Computers & Internet
Samsung DVD-HD850, DVD-HD841 region free code
1. HDCP-Free: Requires only DVD Remote.
a. Power On DVD player, no disk inserted
b. Press "Angle"
c. Press "4", "3", "2", "7"
d. Press "Angle"
e. TV Screen displays HDCP Free
2. Region Free Hack: Requires AIWA/Universal Remote or PDA
The following instructions are for a Pocket PC
a. Download and install TvRemote
b. Download AIWA Mini Audio CCF file
c. Copy the unzipped CCF file to your PPC
d. Run TvRemote on your PPC.
e. Switch to CCF mode on TvRemote
f. Open the copied CCF file. Screen changes to display
the remote.
g. With DVD switched on but tray closed:
i) Press "Repeat"
ii) Press "Program"
iii) Change remote screen and Press "Clock"
DVD display shows "ADJUST"
iv) Press "9" on DVD remote. I also pressed "9" on the
PPC remote so I'm not sure which one did it.
v) No visual indicators occur on DVD.
vi) Power off DVD.
h. DVD is now region free!
on Mar 07, 2010 | Televison & Video
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
CD /DVD burner not identifying the disc
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D or E drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 24, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Xbox not reading disc properly.
This could mean your disc is corrupt, or something is wrong with your drives lense. Call XBOX customer support and they'll help you fix it. 1-800-4MY-XBOX
Jan 11, 2008 | Microsoft Xbox 360 Console
Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. if anyone can help.
Sep 17, 2007 | Panasonic DMRES15 DVD Recorder
I can't play any VCR tapes or DVD's in my Magnavox. Shows E1
It may be a timer setting after a power problem. On page 90 of the manual there are setups for the timers My VCR won't do things without the time set either. The manual may be downloaded here.
Basically get into the setups and set the time and hit enter. I hope this works.
Sep 12, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Zenith XBV443 DVD Player/VCR Logo
112 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
