Csdc DataPilot Data Transfer Suite Logo
a
anthony taylor Posted on Nov 04, 2014
Will your data pilot tether hotspot program enable me to access my laptop computer after downloading the app from my home
David Stewart
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 17, 2014
David Stewart
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
413
Points
Hi, that depends on wether the deal that you have with your mobile phone company lets you use your phone as a hotspot. Contact your mobile company and ask them
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Feb 28, 2011
SOURCE: need app to be able to tether to pc computer for
Sure, I recommend EasyTether which you can find in the Android Marketplace and online at http://www.mobile-stream.com/easytether/android.html. The Premium version of this app costs $9.99 which unlocks secure sites like email. I have personally used this app and it works very well.
nerdydragon
  • 65 Answers
  • Posted on Aug 08, 2014
SOURCE: Is there an app that turns downloaded video into
If you have to proper codecs installed and can watch it on your phone screen you can output to a TV, bit only IF YOUR PHONE SUPPORTS TV OUT. Chances are pretty good it doesnt, most dont if they dont have a dedicated tv out.
Better chance of getting your tv to support dlna, then just pusb video across the network.
How do i tether my lenovo tablet to my new samsung tablet
App drawer > Settings > Connections > Hotspot & Tethering
Note that some carriers disable hotspot, but you can still tether with a third party tethering app like Barnacle.
How do i fix a website?
How to Unblock Facebook at School
Open the Command Prompt on your computer at home (Windows). You can start the Command Prompt from the Start menu. You may not be able to access the command prompt from school, so try this at home first.
  • You can also start the Command Prompt by pressing ? Win+R and typing cmd into the box.
Open Terminal on your computer at home (Mac). You can find the Terminal program by opening the "Applications" folder and then opening the "Utilities" folder.
  • You may also be able to access the Utilities folder from the Go menu.
Type .ping facebook.com and press ? Enter. This works in both the Command Prompt and Terminal. Your system will make a connection to the Facebook website and return the results.
Make note of the IP address. Once the Ping command has run, you will see a series of numbers next to facebook.com in the results. The IP address is four groups of up to three numbers each. Write this number down, including the periods, and take it to school.
Enter the IP address into the browser address bar at school. Press ? Enter to visit the site. Some older blocking systems only block the name and not the IP address, so you may be able to access the site this way.
  • IP Addresses change on occasion, so you may need to repeat these steps after a while.
OR: METHOD 2
Method 2 of 4: Using a Proxy Site
1. Find a list of proxy sites on your computer at home. A proxy is a server that you connect to that allows you to get "outside" of your network. A proxy is also useful because all the work is being done through the browser, so the method works regardless of your computer's operating system.
  • There are several websites that list proxies that you can use. Proxy.org is a great place to start that is constantly updating its
2. Make a list of 10-15 sites to take to school. There's a good chance that proxy listing sites like Proxy.org will be blocked by the school network. Visit the proxy listing sites at home and make a list of 10-15 proxy sites to try at school. list.
3. Try the first site on your list on your school computer. If the site is blocked, try the next one.
  • Proxies that are overused get noticed and blocked, so vary which ones you use on a day-to-day basis.
  • Schools update their proxy site list very often, so chances are that most of your selections will be blocked already. Try to have a large list of proxy sites to try.
4. Select the URL box on the proxy site. Enter "facebook.com" or any other website you wish to visit. Since proxy sites reinterpret the data of website you are trying to access, there's a chance that the site won't load correctly. Most commonly, videos will not load. If this is the case, try again with a different proxy site.
  • Using a proxy site will make browsing significantly slower. This is because the traffic is rerouted through the proxy, reinterpreted and then sent to your location. Be aware that videos and websites may take longer to load, or may not load at all.
Method 3 of 4: Using Your Phone as a Wireless Hotspot
1. Check that your phone can make a hotspot. You will need a smartphone with tethering enabled through the carrier. Many plans in the US allow tethering automatically, though some require paying for the feature to be enabled.
  • Using your phone as the network connection will bypass any restrictions placed on the school network.
2. Open the Settings app on your iPhone or Android.
3. Open the Portable Hotspot/Tethering section. If you can't open this section, then your plan does not support tethering.
  • Android - Tap "More" in the "Wireless & Networks" section. Tap "Tethering & portable hotspot".
  • iOS - Tap "Personal Hotspot".
4. Turn on your phone's hotspot. This will allow you to use it as an access point for a new network.
  • Android - Check the "Portable Wi-Fi Hotspot" box.
  • iOS - Toggle the "Personal Hotspot" toggle on.
5. Get the wireless password for your new network.
  • Android - Tap "Set up Wi-Fi hotspot". Check the "Show password" box.
  • iOS - Tap "Wi-Fi Password".
6. Connect to the hotspot on the computer. Click the computer's wireless network icon and select your mobile phone from the list of available networks. Enter the password from your phone to connect to the network.
7. Connect your phone to the computer via USB if it doesn't have wireless. After connecting your phone with tethering enabled to the computer via USB cable, you should be able to select it by clicking on the network icon in your system tray (Windows) or menubar (OS X).
8.Visit the Facebook website on the computer. Now that your computer is connected to your personal network, you should be able to visit any site without restriction (as long as your personal data plan does not have any restrictions in place).
How do i find my password to tether my samsung phone and tablet using bluetooth
Okay first you pair your tablet and phone together by enabling Bluetooth on both devices and set to visible. You will get a pairing request with a passkey and you just select yes or ok. Then you go into network settings on your phone and select tethering and portable hotspot.. You will choose a password for your connection that you will be sharing with your tablet. Please refer to the following. Hope this helps. How does tethering work?iphone-5-personal-hotspot-web_thumb.jpg Put simply, the process involves enabling the hotspot option on your phone, configuring wireless security with a password to prevent other people piggybacking on your connection, then connecting your tablet to the wireless network just as you would with any hotspot.
You'll have to enter the password the first time you connect, but on subsequent occasions, your tablet should connect automatically. It's the same process if you have a MiFi dongle.
Pitfalls to watch out for One of the potential problems with using your phone as a portable Wi-Fi hotspot is that your tablet will think it's connected to a fixed broadband line, rather than a mobile connection.
This means it could gobble up your limited monthly data allowance very quickly. Whereas your smartphone will avoid downloading app updates and any other large data files on 3G, your tablet could assume that's perfectly fine.
For this reason, either disable automatic updates or downloads. Or keep a close eye on how much data is being used by looking in your phone's settings or via a dedicated app.
On your smartphone, disable the hotspot running when you're not using it as this will prolong battery life.
1helpful
2answers
How do i use my cell phone as a modem for my tablet?
You can either use BlueTooth or setup a Wireless Hotspot (to share your cellular data access to your tablet via wifi), depending on the type of device you have.
Regardless, some carries do not allow this feature by default. You may have to call your cellular provider and ask them if your current account supports 'data tethering'.
If not, ask them to enable it, though there may be a fee.
If you don't want to pay the fee, you can present the point that you are paying for XGB of data, and how you use should not be restricted by the carrier. Sometimes they will waive the fee if you are aware that you can consume data quicker and potentially incur overage fees.
That said, if you are on an unlimited data plan, the carrier may not have a tethering option, as this would allow people to use their cellular data for all their devices at no additional cost. So you may have to switch from Unlimited data, to a data limit, in order to enable tethering.
Hope that helps.
Samsung manuals
If plan is enabled:
  1. From the Home Screen, press the Menu Key.
  2. Touch Settings.
  3. Touch Wireless and network.
  4. Touch Tethering and portable hotspot.
  5. Touch Portable Wi-fi hotspot settings.
  6. A message provides an overview of portable Wi-fi hotspots. Touch OK.
  7. Touch Portable Wi-fi hotspot.
  8. A portable Wi-fi hotspot message is displayed. Touch Yes .
  9. You will now be able to share your phone's data connection with a PC or multiple WI-fi enabled devices.
Sep 02, 2014 • Cell Phones
Wifi hotspot
apps or drop you task bar. it will be in quick settings
May 21, 2013 • LG P925
Tablet will not connect to wifi
When you tether with your Android-powered smartphone, you can connect to the Internet on your computer from any location covered by your cellphone service provider's network. Tethering allows your phone to act as a modem for the computer. Tethering applications such as Tether for Android allow you to set up tethering without the need to root your phone. Before tethering, check with your cellphone service provider to determine how much data you are allowed to use without incurring data charges. Excessive use of the Android phone as a modem can cause you to exceed your allotted data.
Search the Android Market on your phone for a tethering application. Applications such as EasyTether and PdaNet are available to download for free. Download the application from the Market. Installation begins immediately after the download. When installation finishes, an icon for the tethering app is placed on the Android's expanded home screen. Open a Web browser on the computer and access the site specified in the tethering application's description in the Market. Download and install the USB drivers needed to tether from the site. When installation is finished, an icon for the tethering application is placed on the computer's desktop. Tap "Settings" on your Android phone, then tap "Applications." Tap "Development" and enable "USB Debugging." When the field turns green, it is enabled. Connect the phone to the computer with its USB cable. Launch the tethering application on the phone. Launch the application on the computer. Click the option to connect to the Internet in the home screen. When the connection is established, confirmation is displayed in the status window.
Android 101: Tethering
http://www.androidcentral.com/android-internet-tether EasyTether shares your Android smartphone connection with your PC. http://www.mobile-stream.com/easytether/android.html
2helpful
HOW DO I USE MY lg p500 AS A LAPTOP MODAM
you can use lg optimus p500 to tether wifi through usb tethering and portable wifi hotspot.
goto settings,wireless&network settings,tethering &portable hotspot and select it.
now you have to have a data plan working on your phone.
tick the portable wifi hotspot submenu and configure it.
now search for wireless connections from your laptop and you can find your mobile wifi hotspot and you can access the internet through it
How toTeather Toshiba 755-S5320 from AT&T Torch
all android phones (maybe your model type) go to the android settings and look for tethering and mobile hotspot or look for the hotspot app on your phone
1helpful
2answers
Need to use android for Internet connection
Got to -
Settings --> Wireless & Network Settings --> Tethering & Portable hotspot.
Check on the way you want the sharing to work. Try USB tethering which should be the most easy to set up. Tethering will work with Windows Vista, Windows 7 and Linux.
For more information on Android tethering, please visit: http://www.android.com/tether#usb
Top Csdc Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Csdc Computer and Internet Expert? Answer questions, earn points and help others
