I have two Lan extenders one is sdsl Anda Telecom etherwire4000r and the new one is Dlink g.shdl 1504g. I want to connect both the lan extender with 2 copper wire (dead line) to extend the LAN. Is it possible to establish the link. During configuration I made one change in DSL parameter Standard Type (set it to Annex-A in place of Annex-B) and power off the D-link after saving. Now I can not access D-link through web. I tried to set it to factory but the reset button is not doing this. From Hyper Terminal its showing different prompt ">" after booting and commands are not present as given in the manual.
SOURCE: Hi, I am having D-link
The reset provided on LAN extender is for reboot & not the the hardware reset for LAN Extender. Use console cable. Go to hyper terminal mode & you will be able to access LAN Extender irrespective of whatever IP settings are. Then in Menu under software Maintainance you will find Factory reset. Use that option & it will come back to original 192.168.0.1 address. Then you can use it again normally. You still find problems mail me at following address.
Sanjay Mujumdar.
[email protected]
