This is from the Manual. If you want the whole manual, at the end of the instructions, there ia a link to the manual.
Setting Day and Time
Day & Time sets the day and time of your display.
1) Enter the Global Setup menu, and then the Day & Time
submenu option (see "Entering the Menu" on
page 17). Image is for the base.(Here is how)
Entering the Menu
1) In standby mode, press the
MENU soft key.
2) Use
volume up/down to move the pointer to a desired
main menu (DirectLink Mode, Room Monitor, Handset
Setup, Base Setup, Answ. Setup, Global Setup, and
Deregister HS).
3) Press the
OK soft key to select the desired main menu.
To return to the previous screen, press the
BACK soft
key.
4) Use
volume up/down to select a desired submenu and
then press the
OK soft key to enter.
5) In the submenu option, use
an item. Press the
OK soft key to confirm your
selection. For detailed instructions, see the following
sections for the desired submenu option. To return to
BACK soft key.
6) To exit the menu, press
end on the handset or
cid/exit on the base.
2) Press
volume up/down to select the day of the week,
and then the → soft key.
3) Press
volume up/down to set hour, and then press the → soft key.
4) Press
volume up/down to set minute, and then press the → soft key.
5) Press
volume up/down to choose A M or P M, and then press the
SAVE soft key. You
will hear a confirmation tone.
http://www.uniden.com/pdf/TRU8885-2om.pdf
