Leaking
SOURCE: seal leaking on motor side of wayne pc4m pump
Wayne sells parts direct and deals direct with homeowners as well as contractors. You can reach them here.
SOURCE: onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
SOURCE: Onga Pump FM .450 switching on and off although no
I'm afraid I don't have enough information to answer your question but this link should help you to solve the problem. http://www.inspectapedia.com/water/watertank.htm
Testimonial: "Thank you for taking the trouble appreciated. regards Michael Meechan"
SOURCE: The seal between the pump
It sounds like your seal is leaking. You can purchase a new seal kit here.
http://find.westsidewholesale.com/search?keywords=armstrong+h32+seal
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
