Hi. I have a C320 mercedes. the signal lights, wipers,horn do not work . T I can noot change the function on the electronic cluster either. I replace the front SAM unit and it did not fix the proplems. Do you have any suggestions?
SOURCE: 1998 Mercedes Electrical / Electronic Issues
From all indications, most of your devices are controlled by a common module. This would be similar to the engine management computer but has the responsibility for all those mentioned and then some. if you would notice, most if not all are non essential to the engine's performance. Initial suspect would be such a module and/or the sensors, connectors to it. Being such as multi input and multi output, it is perhaps to your advantage to seek the services of a qualified professional. If you are considering a DIY (do-it-yourself), then access to a full service manual would make things doable if not easier.
Often this control module would be under the dash or on any of the kick panels.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Open Hood warning, and wiper blades.
There is a switch on your hood latch. They get damaged sometimes when the hood opens and closes. look down on the latch and you will see the sensor with an electrical plug. There are two 10mm bolts holding the latch in. remove them and the sensor is in the latch.
SOURCE: '87 Cherokee no horn, turn signals, brake lights, wipers, blower
Pull the fuses and check the socket for power on the things that don't work. If there is no power at the fuse box there is a good change the stater igintion switch is toast. it is located on top of the steering colunm under the dash.usally less then 20 bucks All that you mentioned get power from this switch that goes to the fuse panel when you turn the key on
SOURCE: 2004 monte carlo. turn signals dont work. the
try pressing the hazards on and off if they still don,t work replace the flasher unit. it is built into the hazard switch( all one unit ) change this and all will be good.
