Question about Aprilaire 550 Humidifier
I hear to click of the relay, but no water is feeding into the unit
The power is on the furance, I set the humidifer to the approariate setting and I hear the click of the relay, but no water is feeding into the unit?
what can I do?
Godfather814
  • godfather814 Nov 24, 2007
    right on the money. it was the solenoid valve. replaced it myself. thanks for your help.
  • Anonymous Dec 19, 2008
    I took off the feed line for water and it had water pressure, cleaned the filter in the relay but no water to the filter.
Sounds to me like the solenoid valve is your problem and it is likely stuck due to sediment. I beleive Aprilaire has superceeded all of their old valves to the part number 4040 (used on all models of aprilaire humidifiers) - anyone who services these units regularly likely has one in stock usually $60 - 100.
Posted on Nov 21, 2007
Wire schematic for watre feed humidifier to furn
Hi google your humidifer you can get on line manuals to down load
Feb 04, 2010 | Aprilaire 700 Humidifier
The fan is not turning to pull the water into the system but you can hear it running
brand new humidifer i can hear the fan working but the water is leaking all over the floor the water tray is filled and the tank is empty
Feb 02, 2010 | Hunter 33201 Humidifier
Testing a Aprilaire Humidifier 600 Controller
if it works in the test mode then it should be okay but you can get a humidity gauge from radio shack and set in the house to see how high or low its is. the humidifier is only going to give a max of 45% humidity
Nov 27, 2009 | Aprilaire 600 Humidifier
My forced air central humidification system does not work
you need tocheck for power at solinoid valve or continuity of valve where water enters the unit. THe furnace must be on and humidistat calling...
Mar 12, 2009 | Humidifiers
Aprilaire 560 not keeping contant power to cause humid. to work
You may be havig problemm w/ the current sensing relay, try bupassing the current relay and see if the hum. comes on and if it comes on the try rapping the wite wire from the main blower 2 times. hope that helps
Feb 02, 2009 | Aprilaire 550 Humidifier
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Humidifier not collecting water
To both, these sound like de-humidifiers. Is your goal to reduce humidity and dry your room?
If so, if the humidity is low, then the de-humidifier has no work to do. A cheap battery or dial humidistat will help.
If not, check for a clogged filter. No air moving spells no de-humidification.
Also check for a frozen evaporator coil. Same as above but this requires repairs.
Electric dehumidifiers are similar to refrigerators and window AC's. With the fan running, adjust the setting to a lower humidity setting until you hear the compressor kick in. If it does not even at the lowest setting, check the space relative humidity to make sure it has work to do. If it does, repairs may be as simple as cleaning electric contacts in controls or as bad as a refrigerant leak or compressor failure. If its bad, better to replace.
A humidifier adds moisture. If you have a humidifier and want to keep the static off your clothes and keep your nose from drying out, fill the tanks with water and add biocide.
Please do not view my comments as patronizing. Even seasoned engineers have difficulty grasping humidification.
Sep 03, 2008 | Humidifiers
Aprilaire 550 Humidifier Logo
392 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
