Question about Compaq iPAQ H3150 Pocket PC
Sync Problem Compaq PDA isn't recognized by desktop (Windows XP) or laptop (Vista). Won't sync.
2 Suggested Answers
  • 13433 Answers
SOURCE: Compaq IPAQ pocket pc with no software to sync with Outlook
You need active sync
Posted on May 19, 2008
  • 905 Answers
SOURCE: PC/PDA "connected" yet PC won't read PDA
Try this.
With the PDA not in the cradle, unplug the cradle from the computer. Open up the activesync app, and goto File >> Connection Settings. Show Status should be checked, as well as Allow USB Connections. The 3rd box should not be checked if you are not using any serial links. Connected To should be set to automatic unless in corporate environment, Open Activesync should be checked, uncheck allow wireless connection.
Don't plug your cradle into a USB Hub either. The way the hubs operate and what activesync expects aren't quite always the same.
You didn't mention if you have a sleeve for your iPaq or not, also try above with and without the sleeve. Hopefully, the sleeve won't be part of the problem because it is so much easier getting the iPaq into the cradle when a sleeve is installed.
Posted on Sep 02, 2009
0 characters
1 Points
I have a Royal ezVue 7 PDA and I can't get the sync software to work. The computer reads and installs the software from the CD, and the desktop software appears to work, but to sync the desktop to the PDA...
Royal Extreme 7 will not sync properly.
It gets to Deleteing records and locks up.
Both the software and the PDA is then locked into the sync mode.
I have installed newer drivers as instructed by Tech support.
(MwNTXP.inf & rylm100.sys Files)
These files are listed under PDO Desktop>Drivers>WinNY2KXP.
I am using Windows XP Media Center Edition.
I have version 1.5 of the PDO Desktop program.
Is there a later version that works.
Frank Mattox
Sep 01, 2010 | Royal ezVue 7
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: ( When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
Microsoft Money etc. Sync Problem with iPAQ hx2495b
Dec 02, 2008 | Dell Axim X51v Pocket PC
I dont have a softwre to sync my PDA with my pc
there is no such thing as a benq pc suite...
the cd only contains trial version of
pocket outlook <--------- this cannot be downloaded anymore due to the release of the new windows mobile office
presentation dx (pocket point beta) <---- you can download this
pocket version of adobe reader <---- you can download this at
if you need the program for syncing the device do the following:
if your pc is windows vista you dont need the active sync sotware by microsoft... because there is a preinstalled software included with the os... (its called windows device center found in control panel)
if you're using windows xp (all versions except x64) here are the download link of Microsoft Active Sync...
active sync 4.5 (xp sp2 /sp3)
active sync 4.2 (support for almost all xp formats xp, 2003, sp1, media center)
Nov 22, 2008 | BenQ P50
HP Jornada 548 files won't sync with Vista PC
No need to! all u need is to download windows mobile device centre at:
that should help you!please do rate if it does,regards!
Nov 21, 2008 | HP Jornada 548 Pocket PC
Oct 05, 2008 | HP iPAQ HX2490 Pocket PC
Sync probl
Windows Vista is a nuisance, in my own experience.
it has too many issues with drivers et,c.
i,d suggest seeking the setup cd, that would have been packaged with your Hand-held, Or PDA.
This would have had various Applications on it. And Also Active-Sync 3.5. However Vista. Will probably run or use Active-Sync 4.0. which is available from M$ Site. if you download from a computer running Windows 2000 Or XP. then put onto a memory card, or burn to a CD. that you can then install onto your PC.
Long-term, i,d suggest Considering XP. as a more stable and reliable Operating System.
Hope this Helps.
Mike @ Compurepair.
Jul 23, 2008 | NEC MobilePro 900 Handheld
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
Sync toshiba pda to pc w/vista
I also have had this problem.
If you allow the Windows Mobile Device Center to install through the automatic updates, it works for the most part. I've gotten it to actually sync both from the pc to the pda and vice versa. However, it is a little finicky; it takes about 4 attempts before the sync is happy.
Jan 05, 2008 | Toshiba e335 Pocket PC
Compaq iPAQ H3150 Pocket PC Logo
Top Compaq PDAs Experts
Cosma Papouis
Cosma Papouis
Level 1 Expert
Are you a Compaq PDA Expert? Answer questions, earn points and help others
