Question about Mitsubishi Diamond Pro 2020U (White) 22 in.CRT Conventional Monitor
Total loss of picture
I've got a '99 2020u, and over the last several days the resolutions and the colors have failed, leaving me with a dark maroon picture that is impossible to read.
The problem didn't happen all at once, but got progressively worse.
The monitor would act like it was degaussing and then another color and level of resolution would go.
If there's a way to fix this, I'm all ears. I love the monitor which still looks better than any LCD I've seen.
SOURCE: Distorted picture and multi-color words
You need to resolder the convergence chips. This is a very common issue with this line of TVs.'s Mitsubishi forum has detailed posts on how to fix this. Just serach for "55809 convergence" and you should find the info you need.
Posted on Dec 20, 2007
  • 6966 Answers
Most 17 inch monitors upward have two (2) focus adjustments. They are located at the back of the Flyback Transformer (FBT) together with the screen control. They tend to "drift" as you have posted after some time of usage. In the absence of calibrating instruments, you simply have to wing it when adjusting. It might be of help if you use a squarish mirror to view the front while adjusting the controls at the rear. Of course the usual precautions apply when working with live units especially within the high voltage area.
Should you not be comfortable opening the unit, adjusting while "live", you may need to seek the services of a qualified professional.
In some extreme case, no adjustment could and would correct a problem if the CRT has already developed some form of ion burn on its mask and therefore would require replacement. At times, you may need to consider the cost of repairs (parts & service) as well as the down time which may negate justification for repairs and therefore the prospect of a new monitor might be better off.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
  • 3130 Answers
SOURCE: Color loss
Your formatter or what is called the FMT board has bad capacitors on it.
Posted on May 27, 2008
  • 8617 Answers
SOURCE: Mitsubishi Model # VS-50609
try to resolder the convergence amp ICs that may help if not the ICs may need to be replaced. Let me know if you need further assistance.
Posted on Jun 22, 2008
  • 1148 Answers
SOURCE: VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Posted on Oct 05, 2008
Picture is still sharp, but the colr red just disappeared from the picture. It all looks washed out. Any suggestions?
This set used an LED for the illumination source IIRC... a total loss of one color means the loss of one of the three LED's that drive the DMD module. In your case--the RED LED module --or it's driver--has failed. There is NO color wheel to deal with in this set.
Sep 26, 2014 | Samsung HLT6187SAX 61" DLP HDTV
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
and reboot several times then go to Dell
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
Your set contains three projection tubes (picture tubes) the typical life of these are about half that of a regular picture tube television, around 20,000 hours of operation.
As those tubes age the light emission from them slowly starts to decline. Other symptoms include colors being off slightly or a greenish screen. The symptom you are experiencing is called "contrast loss". That means the difference between bright and dark features in your picture tend to get closer together. This loss of resolution (also the picture might start to get fuzzier then it used to be) is a function of your projection unit wearing out. Since it costs nearly as much to replace a set of tubes (all three must be replaced at the same time) as to replace your set. I would suggest taking your time, read reviews and look for a new set.
Jun 25, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Facebook completely GONE!!
Sounds like your account got hacked or simply lost. Did you try contacting Facebook customer support? Ask then to retrieve it from backup on last day you remember having the account.
Jul 07, 2009 | Facebook Social Network
Hello Fixya, Thanks for being available in the Net!!! I have a mitsubishi tv model #ws-55809 and the picture is funky.... It's like it's cartooned. The words are fuzzy a bit and so is the skin...
Sounds like a loss of picture resolution. There is a circuit board in your TV that determines the type of signal (HD or standard definition) The video signal (picture signal) is routed thru this board. Call a local Mitsubishi servicer and get a price on replacement. It may cost more than its worth.
Feb 12, 2009 | Televison & Video
Aten Master View KVME CS1774 Wavy Screen
This is a fairly common occurrence, typically due to signal loss. The longer the total cable run (monitor to computer connector) the less loss you will have. The longest KVM to computer cable I can use reliably these days is about 12-15? at 1024 x 768 at 32 bit color or 8? for 1280 x 1024 at 32 bit color. Things you can do to reduce loss: -Reduce the length of the total cable run. -Increase the quality of the cables used. I only use low loss cables now and have far fewer issues. -Change the video card, some cards can push a signal a longer distance that others. -Reduce the resolution/colors the video card displays. -Try a different monitor or if possible use a different (low loss) cable to connect the monitor to the KVM. Let us know how it turns out or if you have any other questions.
Jul 04, 2007 | Altusen Aten MasterView CS1764 4-port KVM...
Mitsubishi Diamond Pro 2020U (White) 22 in.CRT Conventional Monitor Logo
Top Mitsubishi Computers & Internet Experts
Alun Cox
Shaukat Bhutto
Level 1 Expert
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
