Question about Panasonic Lumix DMC-FX8 Digital Camera
FX8 all button frozen
Camera turns on ok and i can go to all modes but none of the buttons work i can't take pictures and no zoom.When I go to the scene mode all the modes keep scroling and stop temporarely when I push any button. This problem started when I was taking pictures and using the zoom. I have replaced the battery and SD disk.No Luck!I have even banged it on the desk and still no change.
  • 5 more comments
  • Anonymous Feb 14, 2008
    same exact as everyone else. changed batteries and cards. customer service has no answers
  • fx8 user Feb 16, 2008
    my fathers camera has same problem, but there do not seem to be any fixes available.
  • lovesirius12 Feb 26, 2008
    anybody found a solution for this? thanks.
  • kev-b Mar 09, 2008
    Same problem, camera turns on and zooms in I can go to all modes but none of the buttons work I can't take pictures and no zoom.When I go to the scene mode all the modes keep scroling and stop temporarely when I push any button.
  • Anonymous Jun 25, 2008
    have
  • exlumix Jul 14, 2008
    same problem. Zoom activates when the camera is turned on and then it's not possible to press any buttons at all...scrolls constantly in that mode.
    Took it to camera shop and they said it will cost more to repair than to buy a new one !
    One thing's for sure, I'll not be touching another Lumix with a bargepole.
  • rock8boy Jul 21, 2008
    Yes, i have the same issue with the DMC-FX8.
    It doesn't appear to be a battery issue like the posted solution suggests. I've cleaned the shutter button/zoom toggle thinking it was debris or dirty contacts but with no success in fixing the problem. Has anyone sent their camera back to Panasonic for a replacement/repair?
I am not sure if this is a solution. but one time, i turned on my camera when the battery is really drained. usually (when it was broken) it will automatically zoom in. but that certain period when i turned it on, even before it can zoom in, the battery drained and the camera went off. i charged the battery and when i put it back and turned on the camera, it works fine. it is still working fine. good thing i didnt had the repair center fix it, because they charge really high price.
Posted on Apr 28, 2008
I have a Panasonic DMC-LX2 digital camera, I'm based in the UK. Has worked fine for a couple of years, but 2 weeks ago, when powered up, none of the buttons work. Screen is illuminated, lens emerges OK,...
I just got identical situation today, and I have no clue at all. However, I figure that the camera is actually working busy like someone is holding the "UP" button continuously. To see this, power on your camera at any mode except the "Scene mode". After it's on, turn the mode select knob to "Scene mode". I saw my camera menu flashing like crazy. When you press any button, the menu should stop running. But once you don't press the button, the menu start running again.
Please let me know if you have any update.
Sep 21, 2010 | Cameras
My Panasonic DMC-LZ3 camera appears to have locked up
Make sure the scene mode dial is correctly "clicked" into a choice. You could also try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
May 24, 2010 | Panasonic Lumix DMC-LZ3 Digital Camera
Frozen
You have a stuck zoom switch. The fix will require opening the camera, see the following link. This detailed fix is courtesy xscrewdriver (nice job xs).
Aug 01, 2009 | Canon PowerShot A560 Digital Camera
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Turn camera on and it zooms all the way in
hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and remained in this position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then. so try it.
Jun 26, 2007 | Panasonic Lumix DMC-FX9 Digital Camera
Can't take pictures-all buttuns don't work
try a different desk. yes you've done something strange to your settings to get it to totally not work + disable the buttons.
Apr 28, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Camera doesn't respond
Hey bro I have exactly the same problem, when i turn on the damn thing it just zooms right out and just keeps scrolling through the options. I think that it has to be some sort of software problem, there must be a way to reset it!
Feb 27, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Lumix DMC FX8 lens cap opens intermitently,some images shoot rotated 180 degrees
hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and the _Turn Off the Camera and Turn On again_ message appeared on the sisplay. and remained in open position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then.
Feb 12, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Problem - Turn off and turn on again - happens repeatedly
We see this camera often because the lens gets compressed some how and the plastic gears which drive it become damaged, this would be the "buzzing" noise you're hearing during power up. The camera is not passing its power up diagnostics and therefore it shuts down. The lens is not cost effective to replace on this camera, parts and labor exceed a replacement units cost. Hope this is some help. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Oct 04, 2006 | Panasonic Lumix DMC-FX8 Digital Camera
Panasonic Lumix DMC-FX8 Digital Camera Logo
220 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
