L
Lincoln Romain Posted on Nov 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit on,no sound from speakers,no green light from speakers
cwradio73
Level 3:
  • Master 1,162 Answers
  • Posted on Nov 29, 2014
cwradio73
Master
Level 3:
Answers
1162
Questions
0
Helped
363792
Points
3460
These I guess are powered speakers, be sure to plug them in, also have you lowered the volume in the mixer section of you audio? Double clicking or right clicking on speaker will get you into mixer an sound controls.
My gigaworks s750 powers up and lights, but no sound
Hi, have you find any solution? I got the same problem. Can you please email me. [email protected]. Thank you
There is no sound from my speakers
Dose the green LED light up at the front ? . If it does not its a power supply issue. You must have burnt the transformer in the power supply unit. If the light lights up ans there is no sound it could be the Amplifier Chip (IC ) problem. This will involve soldering and desoldering work not to mention procuring the IC.Cos wise the IC just cost about 3$ ans the transformer about 7$.
Have no sound speakers green light is off
The green light represents that the unit is receiving power, if the light is off then the unit is not receiving power. Check the power plug. Check the power switch on the speakers. You may need to push in a knob.
Take care!
damnor01
1helpful
3answers
How do i hook up the speaker to my computer
if you have stereo speakers, connect it to the green audio port on your computer. if you have digital surround, you have green, yellow and black. insert the speaker connectors accordingly.
5helpful
Radio wiring diagram for a 96 thunderbird with premium sound
1996 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
1helpful
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
NO Sound from NEW speaker unit?
Yes the green wire that goes from the speaker should be plugged into the green jack on the PC. An easy test to see if its the computer or the speakers is to have the speakers on and volume up a little and tap the tip of the green plug with your fingers while out of the computer. If it makes a humming or any noise at all while tapping, the speakers are working if not lets check voltage at the power plug or if the unit has any lights on. Gook luck!
4answers
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
2answers
Radio wiring
The factory wiring connector hook-up for the Mustang is:
Radio / Power Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Your best bet is to buy a radio install kit and adapt it to the Mustang connector. Hope this information helps.
 Grubhead
Grubhead
SmartAviator
SmartAviator
