Question about Danby DWM99W Top Load Washer
Tap adaptor leaks
When I hook up the adaptor to the tap to fill the washer it doesn't seal properly. I have tried everything...switching things around, new washers etc...nothing works. What do I do or where can I buy a new complete adaptor..?
  • 3 Answers
I found the problem to be the tap nozzle that was supplied when I bought the washer, it didn't work at all. I ended up going to Home Depot and picking up another one, it has been working well since then.
Posted on Dec 25, 2007
How do i fix leaking tap, it is not the washer type tap
You either need washers, a control cartridge or a seal kit, depending on the brand.
Jan 31, 2012 | Home
Washing machine fills with water while sitting idle.
Another problem could be the inlet solenoid is failing to close properly, this could be caused by either an obstruction in the sealing part of the solenoid valve, a damaged or worn out seal or if the water pressure is too low. (some solenoids require water pressure to close off properly). To test this idea turn off the taps when not in use. If the water is still filling the tub, the back flow / syphoning idea may be valid. Also just to rule the idea out, turn off the tap to the machine and remove the inlet hose, if the tap "drips" this "trickle" of water maybe the culprit. If turning off the inlet tap fixes the problem you may need to replace the inlet solenoid.
Jan 08, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My Bosch washing machine is leaking from the bottom of the right hand side of machine when not in use.
g'day, sounds like the leak is coming from the hose - this is because the leak is occurring when its off. Check seals on hose at the back of machine. You can always find old sets of hoses as well (or buy them), so you can try swapping them over. Keep in mind, with washing machine hoses (like gardening hoses), the seal is at the rubber washers not the thread on the tap... so plumbers tap will not stop a leak, it will hinder the seal.
An alternative solution is simply turn tap's off between washes...
Aug 07, 2011 | GE WWSR3090TWW
I can't get water completely shut off on downstairs kitch faucet. All valves shut off, everything but bypass valve on wtr sftner. Still steady trkl on downstair fauc. Am I just not patient enough?
You might try opening all faucets and outside silcocks after main shut off valve to make sure you aren't just pulling a partial vacumn which can cause some water to be trapped in pipes and very slowly leak out.Thank you.
Mar 10, 2011 | Garden
Leaking petrol tank on gpz 1000rx is it possible to repair the leak if so whats the best way
Try a product called PET-SEAL it is used in the vintage bike restoration game, Remove tap and sender unit ,Clean Tank thoroughly running water through the tank for a couple of hours, then dry the tank thoroughly ( A hair dryer is very good for this )
It is best to leave the tank in a warm place overnight to make sure it is properly dry. seal up the tap and sender holes. Take the PET -SEAL cans and mix together One is the hardener. Pour the PET-SEAL into the tank, put cling film over the filler cap and close, then swish the tank round, upside down, right way up , swish the PET-SEAL liquid all over the inside of the tank, keep swishing until the liquid goes off and starts to dry (Hard work as it is a heavy tank ). Leave the tank for 24 - 48 hours, build back up with the tap and sender unit. Fill with fuel and Bobs your Uncle.
I have used it an Two bikes and it does work.
Nov 19, 2010 | 1987 kawasaki GPz 1000 RX
Leaking taps
Check first if leaking from hoses or under the machine.
Undo your taps, check that the hoses rubber seals haven't worn out. Replace rubber seals, most hardware plumbing sections have them. Also if the actual tap is leaking at the wall, you will have to change the tappets. You will need to close your main water at the timer, then undo the actual knobs, depending on the tap. Once opened take out tappets and replace with copper ones rather than plastic. Then put all back together and switch water on and check if leaking. In case it is the washing machine, try to replace hose or the connector on the back of machine. Make sure also all rubber seals are replaced with new ones. If under machine you will need a plumber. See how you go!
Aug 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Jul 22, 2008 | Electrolux Washing Machines
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
Danby DWM99W Top Load Washer Logo
145 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
