Question about Vizio L32 32 in. LCD HDTV
Channels keep changing
Right now when you turn on the TV the channels keep changing...also the volume will start going up and you cannot stop it
  • 2 more comments
  • juanotero79 Nov 16, 2007
    TV changes channels, volume and input all the time. Even if the TV is off, it will turn on and start changing channels, volume and input. I already changed one TV because of the same problem. The remote does not wwork either.
  • drjerryus2 Nov 27, 2007
    Same here, when i change a channel using the remote control or directly from the tv, it just follows the command non stop, example, changing channels or volume up and down, or inputs etc...  did u find a solution? thanks.
  • Anonymous Dec 22, 2007
    The channels keep changing in my 32" vizio tv WHY?
  • mcotich Feb 10, 2008
    My input, channel and volume controls are uncontrollable! They are scrolling and I can't get them to stop! What do I do?
Make sure there is no other remote control working simultaneously or with a key pressed constantly by mistake. In my case i found the air conditioning remote control with one key being pressed by my furniture next to my bed, it was causing that erratic behavior. As soon i realized, i stopped that remote control and problem solved. I hope this works.
Posted on Nov 27, 2007
When you push a button on the remote, it either does nothing, or the channels start flipping all the way through from 2 to 120 and then start over. It is the same with the volume, if you hit it, it just...
If it doesnt happen when you change the channel or volume on the tv itself then i would recomend getting a new remote. You could probably get one on ebay. Most manufacture remotes will work on all of their tvs.
Nov 18, 2009 | Polaroid Televison & Video
Television turns on and off, turns up volume and changes channels
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Feb 24, 2009 | RCA 27V520T 27" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
Try unplugging the set for a couple of minutes then plug it back in.
Nov 01, 2007 | Sony KV-32FS13 TV
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Dec 18, 2006 | Sony KV-27V42 27" TV
Vizio L32 32 in. LCD HDTV Logo
338 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
