If the beater bar on your Vax Air Reach vacuum cleaner won't spin, despite the fact that the green light is on, there may be a few possible causes:
Belt is worn or broken: If the beater bar belt is worn or broken, it will not spin. Check the belt to see if it is intact and not stretched or frayed. If it is, you may need to replace the belt.
Beater bar is clogged: If the beater bar is clogged with hair, debris, or other objects, it may not be able to spin. Remove the beater bar and clean it thoroughly, removing any blockages or tangles.
Motor is faulty: If the motor that powers the beater bar is faulty, it may not be able to turn the bar. If the above steps do not resolve the issue, the motor may need to be repaired or replaced.
Here are a few steps you can take to troubleshoot the issue:
Turn off the vacuum and unplug it from the power source.
Remove the beater bar by releasing the clips or screws that hold it in place.
Check the beater bar for blockages, and clean it thoroughly.
Check the beater bar belt for wear or damage, and replace it if necessary.
Reinstall the beater bar and secure it in place.
Plug in the vacuum and turn it on to see if the beater bar is now spinning.
If the above steps do not work, it may be necessary to contact Vax customer support or a professional repair technician for further assistance.
It's good that you have cleaned the beater bar and the end of it, as this is often the cause of the problem when the beater bar stops spinning.
If cleaning the beater bar and end of it did not resolve the issue, there are a few other things you can try:
Check the belt: The belt connects the motor to the beater bar and if it is damaged or stretched, it can cause the beater bar to stop spinning. To check the belt, turn the vacuum over and locate the belt. If it is damaged or stretched, you will need to replace it.
Check for debris in the brush roll housing: Debris can sometimes get stuck in the brush roll housing and cause the beater bar to stop spinning. To check for debris, remove the brush roll and look for any foreign objects that may be stuck in there.
Check for a clog in the hose or the suction path: A clog in the hose or suction path can also cause the beater bar to stop spinning. To check for a clog, remove the hose and use a flashlight to look for any blockages. If you find a clog, use a broom handle or similar object to carefully remove it.
If these troubleshooting steps do not resolve the issue, it is possible that there is a problem with the motor or another internal component of the vacuum. In this case, it may be necessary to have a professional repair it.
It's the beater bar brush. Turn it over and use a screwdriver or knife, and run it the full width of the beater bar to remove the hair and string and other debris that get wound up on the beater bar-NOTE you do NOT have to remove the beater bar or take apart anything. As long as the beater bar spins, and there are no missing sections on the beater bar- this will work. Beater bar could also be worn down- be sure that the bristles extend past the bottom of the vacuum- ALWAYS DO THIS WITH THE POWER OFF
It sometimes takes a 2 grunt pull to remove the end caps and bearings from the agitator (called the beater bar). I have had to use a flat blade screwdriver to CAREFULLY pry the end caps and bearings from a beater bar. Be careful not to stab your hand with the screwdriver (It HURTS!!!) Once you get the end caps and bearings off, clean the hair and carpet fibers from the ends of the beater bar and bearings and end caps. If the bearings don't turn easily, dribble some rubbing alcohol on them (I use a spray bottle filled with alcohol) and spin them until they spin freely. Dry the bearings until there is no alcohol in them. Put a drop or two of light machine oil in each bearing (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure they spin freely. Now would be a good time to check the vacuum head and hose for clogs. Push the bearings and end caps back on the beater bar and reinstall the beater bar (with a new belt). Reinstall the foot plate, and your machine should run like new
I don't know what type of vacuum you have, but you should check the drive belt to see if it is damaged. Remove the sole plate (at the bottom of the head) and remove the belt and roller (called the beater bar). check the bearings at each end of the beater bar (they must roll easily and smoothly). If they are bound up, pull them off of the ends of the beater bar and remove the hair, strings, and fibers wound around the end of the beater bar. Lubricate the bearings with light machine oil, and spin them by hand until they spin freely. Reinstall the belt and beater bar, and reinstall the sole plate. While you are at it... check the hose and head to make sure they are not clogged.
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Hello, W/D here. Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized. 1. Turn off the power (unplug). 2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand. 3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc. 4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it. 5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
