Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storage• : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Begin by holding the sleep/wake button at the top right of the device and the Home button at the bottom center of the face at the same time.
Hold them both until you see the screen go black. In some cases, you may need to keep holding them even after the red power-off slider appears. If it appears, just keep holding it.
Wait until the silver Apple logo appears.
When this happens, you can let go - the iPhone is rebooting.
Updating to official 3.1.3 will lose your unlock, possibly forever. You can't downgrade. Lesson is never upgrade the iPhone without checking that the unlock works on the new version.
Hi don't know what OS you are using. I have a 6200 and I upgraded (big mistake) to Vista. I have had this problem when running Vista and by pure chance and out of desparation I did the following and it worked. However if the Fn F9 worked then please let me know.
On boot up press Del to enter system setup
I then went across to the Exit screen and selected Load Optimal Defaults
I then saved the changes and re-booted and it works fine. Could be pure chance
There are two settings for the fob to unlock doors. One is both doors unlock, and the other is the drivers door on the first click, and then after waiting about two sec. pushing again unlocks the passenger door. The dealer has to set this function. I find that if I don't wait long enough, the passenger door does not unlock.
