How to reset deh-x36ui
If there is no reset switch on either the face or sub panel (usually a pencil tip sized indentation on the face or small pencil tip sized hole on the sub panel), you can reset the deck by disconnecting power to it by disconnecting the battery for a couple of minutes if you are unable to remove the radio from the dash and disconnect the wire harness.
SOURCE: my Pioneer DEH-P4700MP keep resetting when car switched off
Did you use a harness to connect the wires?
Could be the power line (red) is connect to the ACC (Accessory) orange line, so every time you switch off the vehicle the power to the stereo is interrupted.
SOURCE: Pioneer DEH-2100IB resets to default
check the yellow wire where it´s put because that wire needs to be connected to direct current always
SOURCE: Pioneer deh-x36ui. Sound cuts out when turned up
Hello there,
When it cuts out, then if you dont get an 'AMP errror', on the display, then it sounds like your speakers are faulty. Try using a different pair of speakers temporarily to prove if its the Pioneer or the speakers.
If its the Pioneer, then back to base unser Warranty or repair shop.
SOURCE: My cd player comes up amp error. Pioneer deh-x36ui
Hello there.
I didn't see this post with 'Amp error' before I answered the other one.
Sounds almost Definitely your speakers cant take the power. They need to be capable of AT LEAST 50 Watts..
New Speakers I reckon.
