Is it difficult to replace the serpentine belt on a 2005 Grand Prix? Any special tools needed?
You will only need to locate the fan belt diagram to replace it on correctly and a 1/2 breaker bar or ratchet to back off the tension er while replacing belts check the tension-er bearing if it feels ruff when you turn it replace it. Check water pump also to see if it turns smooth same with the alt.
Thanks, Just what I needed to know. Found the diagram on the car. Just wasn't sure what was needed.
