We have a Tradewind range hood- model PSL 736. The 2 halogen 50W lightbulbs stopped working at the same time during a thunderstorm...our house was not hit (incase you are thinking that). I have purchased 2 new light bulbs, but the lights are not turning on. The switch to turn on the fan works fine.
How can I check what is wrong? The panel around the lights has screws in it...what would I look for if I take it off?
The screws by the lights probably only hold the fixture in place. If you took the screws out you would only get access to the fixture and maybe some wiring. If you have already replaced the lights you can assume its not the fixtures. Not likely both fixtures failed at the same time. The common problems would be the light switch. You would need to gain access to the switch and then check that for power.
You already know house power is good because the fan is working, But since both lights failed and new bulbs don't fix the problem it would most likely be a switch.
According to their website it looks like that whole front panel should come off including the fixtures and the switches.
MAKE SURE THE POWER IS TURNED OFF......REMEMBER THE FAN WON'T WORK IF THE POWER IS OFF.
Once you remove that you can check the wiring harness for the lights. You may also see wire nuts on the harness double check those as well.
Hi,have just purchased a westinghouse slideout rangehood 900mm model no wrh908iw reciculating,now...
(More)
Hi,have just purchased a westinghouse slideout rangehood 900mm model no wrh908iw reciculating,now find i need a 70mm front facia instead of the one supplied,just wondering how do i remove,where do i get one or could i make one out of timber to match kitchen cupboards,thank you very much rob
I've bought a new cooker hood that filters the air and then re-circulates it. At what minimum height...
(More)
I've bought a new cooker hood that filters the air and then re-circulates it. At what minimum height from the ceiling should it be fitted?
I moved into a new home. Has a 36" cvaliere range hood over the islanded vented out side. 3...
(More)
I moved into a new home. Has a 36" cvaliere range hood over the islanded vented out side. 3 filters. I have no idea how to use the controls other than on and off and fan speed. I see a clock i think and a timer telling me to clean the filters stoppped at 30hr? i have cleaned them but don't know whow to reset anything. The online manual talks plenty of the install but not the buttons. any help would be appreciated
