Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Kp-46wt500 46 try to repair the horisontal ic at the inside of t.v. if  the apperrance of ic are blowing it should be replace it in the model number of i.c.
  • 375 Answers
Try to describe the fault on the tv
Posted on Nov 15, 2007
Cant adjust the convergence in menu colors look ghost,3d looking
You will need to replace the two convergence ICs and then check and possibly replace the pico fuses on the D board and G board. The Sony number one convergence repair kit available from is the correct kit for your model. The kit contains both ICs and the 8 pico fuses plus the CD with detailed repair instructions.
Sep 22, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a similar problem as described as a convergence problem with my Sony KP-53HS30 TV. Can you elaborate further on the solution to repair. Which IC and protector fuses do I replace? Thank you.
Your model uses two STK392-560 Convergence ICs. also there are 6 pico fuses on the D board and two pico fuses on the G board which may need replacement also. The Sony type 1 convergence repair kit from contains the IC's pico fuses and a few resistors plus instructions on CD of how to do the repair.
Aug 08, 2010 | Sony KP-53HS30 53" Rear Projection...
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My sony projection tv has bouble image. can i
Well repair of TV depends on your own skills and if you have any experience of electronics stuff repair then it would not be difficult. This kind of repair requires good parts soldering in PCB expertise.
Your Sony KP-51HW40 seems have problem with convergence out ICs (two ICs) that would be replaced. Both ICs STK392-560 are located on D Board and available in Part Store.
Aug 21, 2009 | Sony Televison & Video
My TV set, an 2004 Sony Model KP- WT510 Rear Projection is having problems with "Convergence" alignment; everything shows double or triple images and picture is totally distorted; I tried to align the...
The convergence output integrated circuits aren't doing their job. These are mounted on a heat sink on the circuit board, but they still get hot enough that sometimes the solder connections to them can break. Resoldering the connections would fix that problem.
It's also possible that the convergence circuit is not getting power, usually be due to failure of one of the outputs, which can cause protective fuses or resistors to blow. This would be harder to repair yourself because it involves determining what parts need to be replaced.
It would probably be worth getting a technician to look at the set and give an estimate for the repair.
Nov 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT500
you need to replace both convergence Ics number STK392-560 its a fairly easy repair that requires basic soldering skills. you can get replacement Ics with free instalation instructions with pictures at the following link,
May 25, 2008 | Sony KP-46WT500 46" Rear Projection...
Fixing the convergence ic's
Do it yourself, its an easy repair and if you go to the following link they have the replacement ICs and they include free step by step instructions on how to do the repair, and they offer free on-line instant messaging with one of thier techs will youre doing the repair, They even have service manuals. Heres the link If you dont know your IC numbers just click on the contact link on the lower left side of thier homepage and send them an email with your model number and they will get back to you quickly with the proper ICs that your model uses.
Apr 08, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Samsung tv
are you sure that is horizontal? what is the line come form left to right of screen? or from upper to lower of the screen?
Oct 22, 2007 | Televison & Video
Floor model
If the IC your talking about has a designation number of IC601, the number is MX0841AB-F. Common regulator IC. Sony says that IC is no longer avaialable. You may get lucky and take out the entire G board and have, or repair the board for you. Good Luck
Sep 17, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
