Question about System Power Supplies
Sunvic roomstat TLX7501
I am trying to replace old honeywell stat. The new sunvic shows terminal 1off. terminal 2 on, terminal 3 C. I have a red yellow and blue wire could you please advise which should go where
0 characters
1 Points
System unit or power supply?
The computer power supply may have failed. Do you get the "post beep"?
If not- remove the BIOS battery, move the jumper to "Clear BIOS" . Insert BIOS battery, and try to boot. Put jumper back to normal position and try boot again. If you do not get the post beep, swap power supply for a known good one, and try boot again. If it still does not boot and give you a post beep, look to see if there is a removable BIOS chip- pop it out and put it back, this will clean the terminals. Go through and reset BIOS, as above, and try boot. If the system is functional, it should now boot up, but prompt for you to run the setup program.
If it does not boot, the problem is relating to motherboard/processor.
Apr 11, 2012 | System Power Supplies
Power supply nps-730ab getting red light in middle flashing and bottom green light on constantly lite. however not functioning properly. have two power supply so this is a redundant system, but still need...
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Oct 01, 2010 | Dell NPS730AB 730Watt Power Supply
I have a HCL Monitor Model HCM782M.For the past 2 years since i bought it the screen was fine.But now the screen shows the CONTRAST SETTING everytime I boot my pc and keeps up popping up ver very qucikly.I...
Mr Ajit in my organisation I have around 20 such monitors which have the same error. This happens due to moisture the mewnu PCB gets shorted and now you are left with only two solution either disconnect the menu pcb from the main board or replace it with a new one
Aug 17, 2010 | System Power Supplies
I have an old computer (not this one)which uses
How do you "warm" the computer, so that it will start properly?
Take a close look at the motherboard.
Look for those round "towers" with "silver" coloured caps.
They are capacitors.
If any caps are _not_ flat, i.e., they are bulging,
or if any caps show brown "rust" on top of the caps,
then those capacitors on the motherboard have gone bad.
Before your motherboard _completely_ dies, backup "everything" to an external disk-drive, verify that the backup has worked, and then either "trash" the motherboard, and replace it. You'll have to reinstall Windows onto the new motherboard -- find the CD/DVD set that you used to install XP.
Feb 28, 2010 | HP and Compaq Pavilion Replacement 200w...
Dell Inspiron flashing amber power light, not charging
I would think the batteries need replacing. That happened to my Dell Latitude CPI. The batteries won't charge past about 3%, so I got new ones and that did the trick. If this is under a year old I would contact Dell about it, if it is under a year old they should replace the batteries.
Hope this helps.
Feb 23, 2009 | Dell Dimension 8400 power supply ** FREE...
HP Pavilion 774y power supply replacement
I doubt you fried the motherboard
I would be taking my old power supply to the store where you purchased it to make sure they gave you the proper one.
Some power supplys do have that extra plug you may not need to plug it in at all
I can't see your motherboard to show you where to plug it in wish i could help more
Jan 15, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Problem with power supply atx-300-12eb3
Faulty I should say, becaue you can repair it. Just replace the Buldgy capacitors. you'll need a soldering iron, soldering lead and a ****** to desolder the components terminals. Remember replace the caps with only the specific values indicated on them and also when replacing them see how you removed them is how you'll replace them and solder them back, if you not sure to do it yourself then provide the Capacitors and asked a friend who can do it for you. But if you think you can afford a new powersupply unit, thats fine.
Nov 12, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Wet Dell XPS M1210
I would try cleaning the terminals on the battery and the computer with an old toothbrush and simple green or other multi-purpose cleaner, that doesn't leave residue.
Jul 13, 2008 | System Power Supplies
System Power Supplies Logo
472 people viewed this question
Top System Power Supplies Experts
Brian Sullivan
Brian Sullivan
Are you a System Power Supply Expert? Answer questions, earn points and help others
