Question about KitchenAid Kitchen Ranges
KitchenAid KERS507Y This is an old KitchenAid but, for its time, was top of the line. It is computerized with digital display. The convection/regular oven does not heat up even though the LED display says that it is working. I don't know if this is an thermostat, chip, sensor or whatever else problem and was wondering if you could help. I don't want to spend a lot of money online buying parts that are not the problem. Do you know of any way that I can diagnose this before I start spending money? Would like to do this myself (kinda handy) but need to do a process of elimination to find the problem. Thanks.
  • 473 Answers
SOURCE: Oven not heating KitchenAid KERC506HWH3
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
Posted on Nov 16, 2007
  • 146 Answers
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Posted on Dec 29, 2007
  • 6 Answers
I've got a Bosch oven and had the same problem.
I found that the thermostat might be to blame. In my case it was very simple - I opened up the back, and where the thermostat connects with wires, there was a little reset switch - and all I needed to do was push it in to reset, and it worked fine again.
I think it's a little protection device that activates when the temperature exceeds the thermostat's working capacity.
(I used to joke to friends that this is the button they put in so that technicians can simply reset and then charge you for the labour!)
Hope this helps some of you, if not everyone - just a pity that I only found this website today, and not in time for your Christmas dinners!
Posted on Jan 24, 2008
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Posted on Oct 16, 2008
  • 23 Answers
SOURCE: Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Posted on Sep 18, 2009
Kitchenaid kera205pss convection oven feature not working
Beth, you either have a failed convection element, part number 9460769, possible bad terminal connection at the element or a failed oven control. A bad element is the most common failure. replacement instructions for a failed heater can be provided.
Apr 20, 2014 | KitchenAid KERA205PSS Electric Kitchen...
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Fan for convection oven not working
Maybe you could throw out the oven and buy a new fridge
Feb 02, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Ranges Logo
102 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
