Question about Sony PlayStation 2 (PS2) Console
Controls second control port does not work
  • 709 Answers
The connector is probably dirty. Open the case and remove the two screws on each side of the control ports. Pull the control port up and you will see where the ribbon cable connects. Flip the connectors hold up to release the ribbon. The connectors hold is the darker piece on top right where the ribbon enters. it flips up. Use your fingernail to get under it and flip it up.
Now that you have the control port out. You can wash and clean the fool out of it. Allow it to dry real good before hooking it back up. This may get your control port working again. While your in there clean up other stuff.
Posted on Nov 12, 2007
Controller ports not working
The PS 2 only accepts the Dual shock 2 controller ( the one with cables) you are using an advance controller. Get an original controller for the PS 2
May 03, 2014 | Sony PlayStation 2 (PS2) Console
My PS3 won't reconize any of my controllers, putting the cable in works, it find the controller, but when I unplug te cable the lights start blinking again and I can't use the controller, what to do?
Hmmm. It sounds like either your PS3's Bluetooth controller is on the fritz, or all of your controllers are on the fritz. Since I doubt ALL of your controllers are malfunctioning, I am betting it's your PS3. I suggest having a friend with a working controller stop by and test his controller against your PS3. IF your friend's controller works, then you know that the PS3's Bluetooth controller is working.
Second step is to check to see if the USB cable is transmitting a trickle charge to the controller. Again, using your friend's controller (make sure he brings his own USB cable with him), try charging his controller with HIS cable first. If after 10 minutes of playing with the controller plugged into the PS3 via USB, you unplug it and the controller still works, then the problem is most likely your own USB cable (it's apparently damaged in some way). Now run down the controller's battery and try recharging it with YOUR USB cable. If it fails to charge, then you know that all you need is a new cable. Just in case, make sure you test EACH of your USB ports. A simple replacement will cost you around $10.
Otherwise, your PS3's UBS port(s) are not properly working and you should send in your PS3 for repairs. As stated above, test each of the USB ports on your PS3. My 60GB one has 4 USB ports, so I would test all 4 of them before sending in the PS3. Then, if you want it repaired, make notes of which port(s) is(are) malfunctioning and send it to an authorized PS3 repair center.
Dec 24, 2010 | Sony BD Remote Control for Playstation 3
I have an old Sega Genesis. went to play tonight and now A,B buttons won't work on either controller even when I switch them. Unplugged the game and reset it...played for a few seconds on a different...
Well it might just be that its old then so the controller ports do that i had a problem with one of
the controller ports on mine and i resoldered it and it worked again after that.
Dec 06, 2010 | Sega Genesis Console
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
SNES Controller 2 Port Not Working
The 2nd Player controller port just might be shot. That or the part of the main board that deals with the 2nd controller. My suggestion is purchasing another controller board (the main board and controller board are separate and easily removable pieces) and switching them out. If the problem persists then the SNES's main board probably has an issue.
Jun 03, 2009 | Nintendo Super NES Console
Ps2 joystick or ports problem.
Maybe you need a new controller that happend to me one time.
Mar 28, 2009 | Sony PS2 Dual Shock 2 Controller...
Controller NOT Working Properly
I just came home to find this same problem. Four blinking lights on the wireless controller and the inability to sync the controller with my 360. On a whim I took out my controller's battery and then reinserted it after a few seconds. Voila! Problem solved. Controller works normally again!
Jan 22, 2009 | Microsoft Xbox 360 Controller
Wireless XBox controller won't sync with the PC adapter
I finally found a solution that works for me (most of the time). I bought a USB hub (un-powered at the moment) and the problem seems to have disappeared. The Hub however isn't the solution. Running the controller or the hub from the rear motherboard ports is.
I was initially using the 360 wireless receiver from the front ports on the PC which are driven by a different circuit on the motherboard than those from the rear of the PC.
When the receiver is run from the rear ports or in my case a hub powered from the rear ports it works most of the time.
Ocassionally the receiver doesn't link with the 360 controller however unlike last time when pressing all kind of combinations of re-sync buttons did nothing, all I do now is press the very tiny white button on the front of the controller and it links up like it should within 1.5 seconds.
I hope this helps guys as the controller is great when working.
Dec 25, 2008 | Microsoft Xbox 360 Controller
When these messages keep occurring it means the controller is either broken, damaged or about to die. I had that once with some games. For instance when I got shot and the controller rumbled it paused and said "No controller present".
Try checking other controllers, try cleaning the controller ports. (use a vaccuum to suck out dust out of the controller ports). And make sure no pins inside the controllers plug are bent or broken. if so: carefully bent it straight. Also check if the other end (the slots) aren't broken. They can be a bit wobbly.
If the problem occurs with multiple controllers which you believe aren't defective try the second controller port (I know, most games require the controller to be in Port 1) but maybe the port is broken. Which can be the result of shoving in the controllers to hard.
Also, just a hint: try not to swap controllers or Memory Card once the unit is powered on. Same goes for cables and other accesoiries.
If none of this helps, and you are sure the controllers are OK: get the console itself to either a Sony repairman or the shop you got it from.
I hope this helps. Please rate.
Feb 08, 2008 | Sony PlayStation 2 (PS2) Console
Only one controler works via the Multitap
did u check the right insert? if so, check one more time.
Dec 31, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
